Old 08-18-2018, 02:00 PM   #1
Awning Polycord Help
Noticed on last couple of outings the polycord creeping out of the awning. Tried forcing it back in with pliers but that doesn't work. Any suggestions appreciated please?
Name:	1 awning cord.jpg
2016 Wildwood 230BH X-Lite
2011 Ford XLT Supercab
Days Camping -
'15 (6) : '16 (32) : '17 (41) : '18 (35) : '19 (10) :
Sebourn is offline   Reply With Quote
Old 08-18-2018, 06:51 PM   #2
Head Rambler
Did you take all the tension off the fabric when you tried to push the rod back in?
Gotta go campin!
Old 08-18-2018, 07:09 PM   #3
Yea, lift roller a little and relieve tension on fabric. Makes it easier to put back in.
Decon Blue is offline   Reply With Quote
Old 08-18-2018, 07:50 PM   #4
No, just extended it all the way out and lifted up a little so not as taute. I didn't want to screw something up I couldn't get back together.
Days Camping -
Old 08-18-2018, 07:52 PM   #5
Might be too much out. It's out about 5 inches.
Days Camping -
Old 08-20-2018, 12:27 PM   #6
Head Rambler
Is the other end drawn into the loop the same amount as the protruding end is sticking out?
If all else fails, you could buy new rod and stick it in the other end as you're pulling the old one out. But really if you lift the tube up and get the tension off the fabric it should push back in the channel.
Gotta go campin!
Old 08-20-2018, 12:37 PM   #7
I'll see if I can push anything similar into the opposite end. If I can't get the end sticking to go back in, maybe I can cut it off and stick the cut off piece in the other end. I have sent an email to Lippert asking what might be done to keep this from happening again. BTW, I have a friend with a fifth wheel and one of his awnings is doing the same thing. Might be pretty common.
Days Camping -
Old 08-20-2018, 01:01 PM   #8
Flybob's Avatar
Spray some windex on it when you try to push it back in. Is should helf reduce the friction and make is slide easier.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 08-20-2018, 04:03 PM   #9
Head Rambler
They normally have a screw in one or both ends to keep it from sliding out.
Gotta go campin!
Old 08-20-2018, 04:27 PM   #10
Thanks, I'll give that a try.
Days Camping -
awning
