Old 08-09-2015, 08:15 PM   #11
I am a transporter- parking many campers 5ers and tt, all different size campers and camping spots.A few basics---number 1- turn off your vehicle radio 2- look where you want to be 3- try to use your drivers side mirror 4- take your time 5- dont get frustrated.6- get out of the vehicle every once in a while to get perspective and a little rest.I do like the suggestion hand on bottom of wheel.
when I first started, I did go to a parking lot and put cones out and practiced.
riverrat958 is offline   Reply With Quote
Old 08-09-2015, 08:18 PM   #12
Witch Doctor's Avatar
Originally Posted by RickRed52 View Post
I'm calling a few driving schools to see if they offer something
Post #5 is great. I could only say make slow turns as you back up, and jockey back and forth til you get in. YOU WILL GET IT...
Coachmen M/H
Concord
2018 / 300 DSC
Old 08-09-2015, 08:19 PM   #13
Canadiancrew's Avatar
Originally Posted by Pod2Vibe View Post
Practice in the biggest empty parking lot you can find, prior to your next trip.
Yea get a few orange cones to setup and a big empty parking lot. If you miss you can hurt anything except the cones.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
Canadiancrew is offline   Reply With Quote
Old 08-09-2015, 08:20 PM   #14
Brother Les's Avatar
Always take your time.
When pulling up to your site, park in the road way and get out and visualize on what you need to do.
Look at all hazards when out of the truck, side trees, depth, overhanging branches above.
When you have surveyed the area and have your backup plan in mind, before getting back in the truck, look at what is beyond the site for when you start backing in.... trees, vehicles, can you swing wide or will you have to 'knife' it in,etc....
Get back in your truck and pull forward and when you see the back of your unit in the mirrors at the closest edge to your 'site', cut your front wheels hard in that direction and stop. If your site is to your right, cut your wheels to the right (left, left), this will jack the back end in that direction and set you up to back into it.
At this point I will again get out to the truck and survey the back end where I am backing into. Is the alignment good or will I have to move forward or drift back a little. I trust the DW and kids as 'spotters', but it is my full responsibility to get the unit into the correct area of the camping spot. Keep all communication going at all times with your spotters, more 'eyes' less problems. Talk, talk, talk.
Get back in truck and reverse and Cut the wheel in the opposite direction (site on right, cut wheel to left) and slowly walk the unit around and into the site. If I have any question in my mind what so ever I will stop the truck and get out and survey the area and look and look and plan the approach and talk to my spotters. I may have to pull forward a time or two in order to line the unit up better on one side or the other of the drive way. I will stop the truck and get out, one, two, three, or as many times as it is needed to safely put the unit where it should be.
When you get in a hurry, bad things happen. Slow down. Stop, get out and look, take your time and trust your spotters, they can see things you cannot, but also when you get out you may see something that they did not.
Brother Les
Old 08-09-2015, 08:28 PM   #15
boatman
boatman's Avatar
Don't try to back all the way in in one motion, long trailers especially 5th wheel react to slowly if you get to far jack knifed trailer at a 45 to 90 degrees angle to each other turn the opposite way and pull forward a little bit this will straighten you up. Turn back the way you were and back up a little the objective is to get TV and trailer in line so you can see where your going.
boatman is offline   Reply With Quote
Old 08-09-2015, 08:30 PM   #16
Cyber Phrenologist
Radio's Avatar
1. Find a friend (or friend of a friend) who is a professional truck driver.
2. Set up the cones in a parking lot
3. Practice doing what he says until you get it.
4. Take the truck driver out for pizza and beer.
Done.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 08-09-2015, 08:49 PM   #17
I appreciate all who have responded!
RickRed52 is offline   Reply With Quote
Old 08-09-2015, 09:22 PM   #18
Twistedpairs's Avatar
Easy task. Most drivers psych themselves out and make it a bigger task than it actually is.
First thing, break it up into smaller tasks, each completion is a mini victory.
Second task, make sure you will fit! Both width and length. Doesn't do any good to try if it doesn't fit.
If you can't line up to back straight in, back so you are turning to the driver's side, you'll see more. Your ground guide aka DH/DW, can watch the passenger corner you can't see and do the rain dance in the mirror ( while standing on the driver side). Turn the bottom of the steering wheel the direction you want to go. Easiest way to remember when frustrated!
In the beginning treat it like great BBQ, slow and low. Like everything speed comes with experience and experience knows better. We've all been there, ( I've even backed cars out of tight spots for people that made it seem worse than it was) it is very understandable if you need to stop, get out and check or even go around the loop another time. Remember, you pay for the damages if you hurry, not the impatient "expert" who isn't willing to get out and offer assistance.
Twistedpairs is offline   Reply With Quote
Old 08-09-2015, 11:36 PM   #19
Terier's Avatar
For me it was lots of practice, backing up slowly while watching how the trailer reacts but also removing the anti-sway bar first before backing into a site. What gets me into more problems is trying to get the tt positioned perfectly. I have learned that 'good enough' works.
Old 08-10-2015, 10:56 AM   #20
I agree with the previous poster that what works best for me is to:
1)pull well forward of the site, my TT wheels need to be 5+ feet forward of the site. This give my TT time to react and begin turning in time.
2)Try to pick sites on the driver's side of the road. I have much better site in my driver's mirror than the passenger one.
3)make sure your mirrors can see the TT wheels at all times.
4)Hand on bottom of wheel, move in direction I want the TT to go.
5)With wheels in mirror, make the wheels follow the edge of the pavement into the site. Pull forward a few feet to straighten out and go again if necessary.
I have my husband stand where i can see him in my mirrors. If I can't see him, I just stop. He gets the picture and moves where i can see him so i can continue.
His job is not to micro-manage me as I back in. He just stops me if I'm going to hit something, or tell me when to stop backing up because we're done. It's also his job to survey for making sure placement allows for the power and water to hook up and the slide to extend without hitting a tree.
I used to get really nervous if someone was waiting on me. I now have confidence that I can get it in the site, approximately where I want it, in 1 min or less.
2012 Ford F-150 3.7L V6 -- SOLD
2007 Rockwood 1640 LTD Popup -- SOLD
2004 Bantam 19 HTT -- SOLD
2015 RAM 1500 5.7L V8
2015 Coachmen Freedom Express 292BHDS
Loraura is offline   Reply With Quote
