Old 07-15-2018, 02:43 PM   #1
Bal x chocks with close axle spacing
Hi folks!
We have a 2109S coming in soon, I want to reduce trailer movement as much as possible, looking to use the Xchocks.
Question is the 2109S has the tires pretty close together, anyone here using the Xchocks with a 2109S or similarly close axle/tire spacing?
Thanks for any/all input!
6CD
6CatDaddy is offline   Reply With Quote
Old 07-15-2018, 02:45 PM   #2
HONDAMAN174's Avatar
Yep. Big difference in movement when my little elephant and her friends move around.
Just glad to get away
Old 07-15-2018, 03:07 PM   #3
kfd82's Avatar
Originally Posted by 6CatDaddy View Post
Hi folks!
6CD
There is a regular size and a large size, get the regular size and they will work.
I have a Rockwood 8311WS with very narrow spacing between the tires and they work for me.
Have to close them all the way before they will fit between the tires.
kfd82 is offline   Reply With Quote
Old 07-15-2018, 03:37 PM   #4
DaGrinch's Avatar
Hi folks!
6CD
On our '08 Roo and '14 Flagstaff, I used our x-chocks. Initially for the Roo, I elongated the slide holes a bit. Helped immensely in the ability to slide the chocks in between the tires with little effort.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 07-15-2018, 03:52 PM   #5
Denver To Yuma In 90 Days
I use them always!
Done so on my last two trailers.
"Just because someone has been "doing it for years with no problems" doesn't mean YOU should!"
2015 Heartland Prowler P292 5'ver
2015 Chevy 2500HD 6.0L Gasser w/4.10 rear axle
JohnD10 is online now   Reply With Quote
Old 07-16-2018, 02:09 PM   #6
rsdata's Avatar
I have used these (small size) on my 2014 Shamrock (Roo) since 2105... work well and are easy to carry...
2014 Shamrock 183
2014 RAM 1500 Bighorn Crew Cab, HEMI, 3.21 gears, 8 Spd, 4X4
rsdata is online now   Reply With Quote
Old 07-16-2018, 02:40 PM   #7
Originally Posted by rsdata View Post
I have used these (small size) on my 2014 Shamrock (Roo) since 2105... works well and are easy to carry...
I didn't know that wheel chocks would work on the Starship Enterprise!
No wonder that the warp drive wouldn't kick in!
Couldn't resist...
Old 07-16-2018, 02:46 PM   #8
X-Chokes
I have 2 3/4" between my 14" tires and it works. That is about the smallest gap I would recommend. I see some benefit w/ them on our 27.5' trailer. These do not replace regular wheel chokes. We do have a V-Lite Flagstaff and have decided it will have some movement regardless. Tried slide jacks also, but concerned of damage that would be done if tire goes flat. Jacks to me may have had more benefit, but feel X-chokes are safer. Be sure to install before putting slides out. DUH-done it.
Tundra 2014 is offline   Reply With Quote
Old 07-16-2018, 02:50 PM   #9
jeff64's Avatar
I have the smaller camco ones they do what they're supposed to do but I do use a couple jacks on the frame for and aft of wheels
2016 Flagstaff 27VRL Emerald
14K Equalizer
2014 GMC 2500HD CC 4X4 6.0L
Old 07-16-2018, 02:55 PM   #10
Hi 6CD,
The BAL-X Chocks should do the trick for you. If interested I have an unused pair that I'd like to sell. Below is a link to the classifieds within this forum. The ad says $65 but I'd take $55 plus shipping.
BAL X-Chock Tire Locking Chock Qty2
Matt
2013 F150
2014 Salem Hemisphere 282RK
Lowes48fan1 is offline   Reply With Quote
axle, chocks
