Old 06-08-2015, 05:28 AM   #1
Ball hitch size
Will a 2" ball work okay on a receiver that had a 2 5/16" on before?
dcooke12 is offline   Reply With Quote
Old 06-08-2015, 05:39 AM   #2
davel1971's Avatar
NO
David & Lynn
Old 06-08-2015, 06:14 AM   #3
Okay thanks!
Old 06-08-2015, 06:22 AM   #4
tjm
I'm not sure what you're asking. You can't pull a trailer with a 2" ball when the trailer requires a 2 5/16" ball. But you can switch the balls on the receiver/ shank to pull a different trailer.
Sent from my iPad using Tapatalk
tjm is offline   Reply With Quote
Old 06-08-2015, 06:43 AM   #5
TURBS's Avatar
You can take a 2 5/16" ball off a receiver and put a 2" ball on it in its place "yes" if the shank size is the same.
So if the 2 5/16" ball has a 1" shank and the 2" ball has a 3/4" shank then "no"
"If that's what your asking"
TURBS
08 duramax tuned n modded
2011 32bhok Sabre
2015 camping "9 nights"
Old 06-08-2015, 06:49 AM   #6
What are you trying to do/hook up/change? Youroo!! PS
Old 06-08-2015, 06:59 AM   #7
waiter21's Avatar
If you have an occasional need for the 2 5/16 ball, maybe just purchase a new ball mount and 2 inch ball. You might discover that it only costs a little more to buy the mount with the ball on it than it does to buy just the ball.
Its a lot easier to swap the dropdown mount than it is to swap balls.
2001 Coachmen Mirada (Ford F53 6.8L V10) - Toad 2003 Saturn Vue
It won't do MACH 2, but I can get a sandwich and take a pee.
waiter21 is offline   Reply With Quote
Old 06-08-2015, 07:04 AM   #8
MilCop4523's Avatar
Reese 2 inch reciever (i jsut purchased a drop down unit) was 29.99$ Canadian. the ball was 15$ Canadian.
if your trying to use a 2 inch ball in a 2 5/16's reciever - it will not hold onto the truck for very long - if at all.
TV 2018 Ford F250, hauling a 2018 KZ 331 TH 12 Sportster 5th wheel, packing a 2015 CF MOTO 800 U-Force SXS
MilCop4523 is offline   Reply With Quote
hitch
