Old 07-12-2010, 06:09 AM   #31
I think I am going to try the Calgon stuff and see if it helps. I do have some build up in the tank from the trip I just got back from 2 days ago. So it looks like I will be doing a little flushing..... I just hope it all comes out.... first time I have had this problem
2006 FR/Wildwood 27BHSS
2006 Dodge laramie 5.9 CTD
northstarfire0693 is offline   Reply With Quote
Old 07-12-2010, 11:01 AM   #32
We had some odor from the black tank and the chem we used didn't work. I read somewhere about using the Calgon water softner and detergent and we did that and added some water. We let it sit until we went camping and dumped when we got there and added both again to the tank. We no longer had the odor and we believe it works much better than the chems. We are believers.
Donna=Me Tom=DH
2 DD's-grown, 1 DS grown, 1 DIL
4 DGD's, 1 DGS, 1 Pekingese(7/1/1999-6/18/2016)
2011 Shamrock 23ss
2000 Suburban 1500 4 X 4
ngts camped 2016-24 so far. reservations for 11 more
ilovecamping is offline   Reply With Quote
Old 07-26-2010, 08:43 AM   #33
Iggy's Avatar
Additional agitation in black water tank
If you don't have a black water cleaner sprayer built in and have toilet paper and other possible solid waste that just won't breakup and go out try this.
Before you leave the camps site or from home dump a few bags of ice cubes down the toilet. Hopefully it isn't 110 degrees out but the idea is to have the trailer move down the road and the ice as long as it is a solid will hit the sides and bottom of the tank and breakup anything that may be solid or even stuck on the sensors.
I used this when my sensors were covered with paper and wahtever.
It worked for me.
Just another solution if you have cooler temps and ready to drive down the road. Oh yes you should dump the stuff after your drive down the road .
Old 02-14-2011, 03:00 PM   #34
I want to add the following step to black tank maintenance and use; once you empty the black tank, be sure to flush some water (about a toilet bowl full) into the tank along with the laundry soap and softner before using. It will help keep the solids from sticking to the bottom of the tank. (been there experienced that) I use all of the methods described in this thread, and have been very happy since doing so.
Boondoggle is offline   Reply With Quote
Old 02-19-2011, 05:41 PM   #35
tank maintenance
Having trouble finding calgone powder water softner, i have been to wallmart, target, walgreens and chain food stores such as foodlion and safeway. were shall i look
tommyanderson is offline   Reply With Quote
Old 02-19-2011, 07:32 PM   #36
MotocrossCamper's Avatar
We just bought a bunch of boxes at Kmart. It's the only place we have been able to find it.
MotocrossCamper is offline   Reply With Quote
Old 02-20-2011, 01:29 AM   #37
CampeRooo
rthrbelsewhere's Avatar
I thought I saw someone had some for sale in the Classifications section - http://www.forestriverforums.com/for...lgon-9109.html
Where we've been:
2000 Rockwood Roo M-18 Hybrid
2006 Dodge Ram 2500 Auto 5.9 Diesel
Gone but not forgotten -1986 Rockwood 1003 PUP
rthrbelsewhere is offline   Reply With Quote
Old 04-02-2011, 06:38 PM   #38
kalik282's Avatar
Buy Calgon @ Kmart
Here's the link to the Powdered Calgon @ Kmart. Click the "Check Other Stores" for a location near you.
Clothing, Toys, Electronics, Jewelry, Jaclyn Smith - Kmart.com
John & Nicole
2004 Ford Excursion 6.0L 4x4
2011 Flagstaff 831FKBSS
Nights Camped: '06=122 '07=12 '08=18 '09=10 '10=18 '11=28 '12=16
kalik282 is offline   Reply With Quote
Old 04-03-2011, 11:48 PM   #39
Willybgh's Avatar
I was able to find it in Walmart in Ontario.
Chris
TV: 2007 GMC 1500 Crew Cab 5.3L
Brake Controller: Tekonsha P3
Hitch: Equal-i-zer 4 point wd/sway control
Trailer: 2015 Cherokee 274RK
In Past:
2011 Grey Wolf 26RL, 2009 Cikira 19 EXP hybrid, 2008 Clipper 108st (pop-up)
Willybgh is offline   Reply With Quote
Old 01-24-2012, 09:31 AM   #40
westyguy's Avatar
Interesting exchange. Is Calgon different or would any water softener work. Also, why not use the liquid form and avoid the issue of dissolving?
Harland & Nita from Texas
Rusty & Coffee - Guard Dachshunds
2012 Sabre 34REQS-6
2011 F-250 CC/SB/6.2L Gas/2X
Nights Camped 2012 = 14
westyguy is offline   Reply With Quote
