Old 09-04-2014, 12:16 PM   #1
Explorer
Black Tank cleaning, I think I知 different
I dump differently than most; I have never seen anyone do it like this and it seems to work. I don稚 have a built in flush system.
I start dumping by wanting a slight tilt to help everything flow(wanting and getting).
I hook up a clear SureFlow so its easy to see and easy to add water.
I like to shoot some water down the sewer hose first to help keep things from sticking, plus this test all the connections.
Pull the valve and let it dump
THIS IS MY UNIQUE PART: a back flush-slosh
I take two feet of sewer hose and make a dip and lift the end of the dip higher than the bottom of the black tank.
I turn on the SureFlow water jet and let the dip fill with water(gallon or so) as well as the bottom of the tank(3-5gl-ish).
Then I lift the two foot dip of sewer hose forcing the water into the tank than I lower the dip again. I do this lowering and raising of the sewer hose several times sloshing water back and forth in and out of the black tank. I can get a good rhythm going and can only believe the water in the tank is agitating.
Then drop the high point of the dip and let the tank dump.
I do this back flush slosh at least twice but up to four times until the water comes out clean. I do the grey tank too just not as much maybe once no more than twice.
I always open and close my valves while clean water is running through them at the end. Then I close the valves leaving the water running and shake the sewer hose all the way down the line to be sure its nice and clean.
I always add 3-5gl of water and a toss in deodorizer/cleaner when done. I try to dump when I leave a campground, bouncing clean soapy water down the road.
Other than back flushing, I do several things that I believe keep the tanks clean and operating well
First started with the purchase of the camper, I like a straight shot out of the potty, I like very short straight runs out of the tank and I like a big tank so I can easily go 6-8 days.
I changed out my potty, the original one had a large open, hard to clean, cavity between the flush valve and the floor flange. My new potty has a straight pipe from valve to tank.(I had posted this change with pics)
I talk to(train) my family about using the potty. We only use the best thickest softest paper one can buy which could/should cause problems. Use two squares wipe fold wipe toss, two squares wipe fold wipe fold wipe toss and if you need to wipe more flush and start over. The idea is more water, easy on the paper but do what you need to. Its hard to train guest but I talk to them too, especially if they are there for more than a day or two. My standard saying is 兎verything you put into my potty I have to get back out so please be nice
I always do a major cleaning of the black tank at home soon after we get home. One back flush-slosh, I use the wand down the potty twisting turning and angling, then several times I fill the potty with water up to the rim and flush, then back flush-slosh one last time to be sure it all came out clean.
Also at home for grey tanks I use 2-3 gallons of very HOT dish soapy water and dump this down each sink and shower drain to clean out the P-traps and scum in the lines.
I also think ahead when camping and do a major tank cleaning about every 3rd-5th dump. Knowing or not knowing where we are going makes a difference in how I dump. Its much easier, less rushed, when we池e at a full hook-up site.
A quick cleaning at a dump station will take me 15-20 minutes, pull in to pull out. If I am doing a major cleaning it might take 20-30 minutes.When I am at home I take 45 minutes with hose and connector wash/rinse . I am always courteous, of others but almost never run into others on weekday mornings.
Its what I do and its has worked for us through two campers.
Hope something in this post might help
John
John
2011 Wildwood T26BHXL
2004 Yukon XL Denali
43yrs of camping; one lucky guy
YoungKopernik is offline   Reply With Quote
Old 09-04-2014, 08:13 PM   #2
Great info! Your are definitely into cleaning that black tank! Lol. I loved your wipe fold wipe toss technique haha!
2006 Salem Forest River
392 FKTB
2006 Wildwood
392 FKTB
Jimh64 is offline   Reply With Quote
Old 09-04-2014, 08:21 PM   #3
dan-nickie's Avatar
Yes, I also think you are different.
Thanks for sharing.
Dan
2014 Berkshire 390RB-60
dan-nickie is offline   Reply With Quote
Old 09-04-2014, 08:26 PM   #4
GreenImp's Avatar
Send a message via MSN to GreenImp
I like your idea of lifting the far side of the trailer a tad, I've thought of this myself. I would want to see the bottom of my tank before I bothered with it though...depending on where the exit is, it may or may not make a difference (my trailer has an enclosed underbelly).
'04 GMC Sierra 2500HD, CCSB, D/A, MaxBrake, B&W Companion, Retrax Pro, AR Power Steps
2013 Rockwood 8289WS w/Diamond pkg
1969 Camaro RS/SS Convertible
Dad's old 1968 Empi Imp (recently recovered from under 21 years worth of boxes/dust)
GreenImp is offline   Reply With Quote
Old 09-04-2014, 08:31 PM   #5
B and B's Avatar
Were i flush in Provincial Parks we have no connection for black tank flush. I do have the trailer on a angle and let er rip. Then ad some soap and water. When i get home i flush the black tank and rinse it out. No issue at all. When i do have Full hookups, only once this year, i flushed a lot and didn't really notice any major amount of bad stuff.
Next time out I will try this back slosh method,
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 09-04-2014, 08:47 PM   #6
I have heard about the "geo method"
Do you know how that works?
392 FKTB
2006 Wildwood
392 FKTB
Old 09-04-2014, 09:10 PM   #7
Ret E-9 Anchor-clanker
donanddona's Avatar
Been using this method for three years and the flushing wand is gathering webs..
donanddona is offline   Reply With Quote
Old 09-04-2014, 09:14 PM   #8
What is the recipe? I hear water softener and liquid soap?
392 FKTB
2006 Wildwood
392 FKTB
Old 09-04-2014, 09:23 PM   #9
B and B's Avatar
I use cheap dollar store laundry soap and softener. Works.
Old 09-04-2014, 09:56 PM   #10
After dumping and flushing with the tank washer and before we leave the campground, I put about 2-5 gal of water in the tanks along with about a half gallon of SuperClean-Pinesol-water mixture and 2-3 packets of dishwasher soap. Immediately after setting up at the next campground or home, I dump the tanks again and flush with the tank flusher. Seems to work fine for us. We also have the Blue Streak that mixes a solution of SuperClean-Pinesol-water with each flush, so all liquid in the black tank has SuperClean-Pinesol in it.
black, black tank, tank
