Old 09-30-2018, 10:55 AM   #1
Black waste tank
Does anyone know if it is safe to use RidX in the black waste tank? If it is what is a safe time limit to keep it in there?
happyttowner is offline   Reply With Quote
Old 09-30-2018, 11:40 AM   #2
Why would ya want to . RidX promotes growth , and I would see no advantage !
Its probably safe though !
wanderingbob is offline   Reply With Quote
Old 09-30-2018, 12:05 PM   #3
Lacey's Spring, AL
formerFR's Avatar
flushing with plenty of water is always the best for holding tanks...we've never ever used anything other than a splash of dawn every now and then, down the toilet, just to add some 'slipperiness' to the tank, and driving a while, before dumping, to 'clean' the tank.
The Turners
'14 Thor Palazzo 33.3 diesel
KingTailgater2 Dish, 100w/5amps roof SOLAR, BlueOx,
100,000+mi since '14, US, Alaska, Canada, now Lacey's Spring, AL : )
formerFR is offline   Reply With Quote
Old 09-30-2018, 12:07 PM   #4
Many on here have reported using RidX with favorable results. If your situation makes you believe you need to use it, go for it.
Days Camped: '16=46 '17=30 '18=51 '19=36
Old 09-30-2018, 12:37 PM   #5
The black tank is a HOLDING tank, not a SEPTIC tank. I would assume if you're like most of us, you dump it within 4-5 days. I wouldn't waste my $$ on RidX.
2011 Traverse LT, 3.6L, FWD
Old 09-30-2018, 12:54 PM   #6
I would think they are about the same thing one just holds it longer!!!!!!!!!!
Old 09-30-2018, 02:51 PM   #7
Yes, but why? Using more water per flush will fill your tank faster, but it ensures a more aggressive outflow when you dump.
--2005 F350 Superduty Crewcab, 6.0, 4wd, short bed, 3.73 gears;
--2016 Montana 3711FL, 40'
--2014 Wildcat 327CK, 38' SOLD
phillyg is offline   Reply With Quote
Old 09-30-2018, 03:19 PM   #8
X2
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 09-30-2018, 03:30 PM   #9
Denver To Yuma In 90 Days
The RidX will definately help out the campground's septic system...but not yours!
I use those TST orange pod thingies just to control the scent...
And occasionally will drop a pod of Commando and about 15 gallons of water down there before I roll to clean off the sensors.
JohnD10 is offline   Reply With Quote
Old 09-30-2018, 07:42 PM   #10
You must be a city dweller. I had a septic for 35 years. Sounds like you don't know much about septic systems.
black, tank
