Old 10-15-2012, 02:37 PM   #11
cogito ergo moo
Cowracer's Avatar
I greatly prefer to blown out lines as a method of winterizing as opposed to using anti-freeze.
My procedure is simple, and takes about 10 minutes start to finish. I can winterize the camper and then take it back out anytime i wish. I know guys who use pink-stuff and miss out on a few nice early spring camp-outs cause they don't want un-winterize it till they are sure the freezing weather is over.
My Class-A's previous owner used pink stuff, and I could never get rid of the taste from the freshwater tank. It was noticable no matter how many times I rinsed out the tank.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is online now   Reply With Quote
Old 10-15-2012, 02:46 PM   #12
Tim
X2 I did the full anti-freeze bit last year for the first time and never again.
Len & Cheri is offline   Reply With Quote
Old 10-15-2012, 03:15 PM   #13
Fulltime family RVer
This is the first winter with my fifth wheel and haven't decided if I'm going to anti-freeze. But, if I do, I think I'm definitely NOT going to put it into my FW tank or HW heater.
ependydad is online now   Reply With Quote
Old 10-18-2012, 09:16 PM   #14
UT Cardinal's Avatar
I also did the blow out method to winterize my 5th wheel; however, now I wonder about the water pump and the line from the pump to the first pressure valve (?). Could there be water in these locations if you provide the compressed air from the exterior city water connection?
__________________________
2014 Ford F-350 Lariat Crew Cab
2013 Cardinal 3030RS
Cummings Onan 5500 generator
Hitch - Husky 26K slider
Winegard SK 3005 dish
UT Cardinal is offline   Reply With Quote
Old 10-18-2012, 10:28 PM   #15
Originally Posted by gartan View Post
I have recently purchased a 2013 Grey Wolf 29BH. I plan on blowing out the lines when I leave my hunting camp on sundays. Can someone provide a picture on how the valves should look when I am blowing out the lines?
I needed info on winterizing my Cherokee 23DD and stumbled across this sight, (no manuals with unit and Forrest River had no useful info. Did it for the first time today. I drained all the drops and the tank and recapped them and drained the hot water heater. The cheap buggers only put one 3-way valve at the inlet of the hot water heater so if I would turned it the RV anti-freeze would have just went out the inlet of the hot water heater. So I took the outlet of the hot water heater off and plugged it. Then made up a suction hose to draw out of the RV anti-freeze jug. It took about 5 quarts, let it run a little longer to make sure the traps are full. Also took off the shower hose and drained it, and drained the water and RV anti-freeze out of the holding tanks. It took about an hour for the first time, now that I know what needs doing, should be a 30 minute job or less depending on how much water is in the tank.
With all the drop drains in these units I don't know how you would blow out all of the water, and get the water out of the pump. It's pretty easy and quick to winterize these with RV anti-freeze. I live where -20 to -30 below zero are the norm, so I need it done right.
Mark
Mark2x2 is offline   Reply With Quote
Old 10-18-2012, 10:34 PM   #16
TURBS's Avatar
Did you drain and remove the water filter?
Run antifreeze through toilet and leave some on the seal?
It may not have one but most do.
Turbs.
Old 10-19-2012, 08:28 AM   #17
Turbs.
I forgot to mention I by-passed the filter earlier. By leaving some on the seal, do you mean not flushing all of the RVAF? If so I'll dump a little in it.
Mark
Old 10-19-2012, 08:39 AM   #18
TURBS's Avatar
Mark
Yes dump some antifreeze in the toilet but don't flush it down.
The seal needs to remain wet .
You bypassed water filter but did you drain the cup and remove filter?
There may also be a little strainer by the wp make sure it's drained.
Looks like u did good!
Turbs
Old 10-23-2012, 09:56 AM   #19
cogito ergo moo
Cowracer's Avatar
perfect example this weekend on why I blow out lines instead of using anti-freeze.
I had winterized the Roo 2 weeks ago. Figured we were done for the season, coupled with the fact that I have had to scrape frost off the windshield a couple of times.
Right now in St. Louis its 68 degrees calling for a high of 80. This weekend will be in the low 60's for highs. We have our annual adult Halloween costume party (or as I like to call it, The Defilement of Our Livers) and I am gonna spot my camper down at my buddies place where the party is. That way I can get thoroughly and morosely hammered, and not have to worry about driving home.
Had I done the pink-stuff, using the toilet or sinks would have been out of the question. After I get done bleeding to death from my eyes, I'll haul it home and blow the lines again.
tim
2016
Rallies Attended:
Old 11-02-2012, 06:10 PM   #20
dsotmoon's Avatar
what kind of compressor do you guys use for the blow out? i know it's recommended to be an oiless one, but is one of those portable tire type compressors enough or do you need a bigger "pancake" style, or...???
Joe
Salem, VA
2011 Dodge Ram
2013 Rockwood 8319SS
dsotmoon is offline   Reply With Quote
