Old 11-02-2012, 06:25 PM   #21
Fulltime family RVer
I'm using a 3.5 gallon pancake compressor mostly (well- solely) because it's what I bought for filling my truck's tires.
ependydad is online now   Reply With Quote
Old 11-03-2012, 02:47 PM   #22
dsotmoon's Avatar
thanks, i bought a 60,00 oilless pancake from harbor freight this morning, should do the trick just fine
Joe
Salem, VA
2011 Dodge Ram
2013 Rockwood 8319SS
dsotmoon is offline   Reply With Quote
Old 11-03-2012, 03:32 PM   #23
What pressure does your new oilless reach? How are folks limiting the pressure to 50 or so psi?
ofranco is offline   Reply With Quote
Old 11-03-2012, 03:51 PM   #24
dsotmoon's Avatar
I think it reaches 100 psi and it has a build in regulator to set the psi @ whatever you need it to be!
3-gallon-100-psi-oilless-pancake-air-compressor
Joe
Salem, VA
2011 Dodge Ram
Old 11-03-2012, 05:00 PM   #25
rattleNsmoke's Avatar
Go Hokies! You'll need a compressor delivering a steady 25-40lbs per sq inch of volume to effectively blow the water from your lines. anything less will take a lot of time and get frustrating. If you don't own a compressor with a storage tank, then just use RV anti freeze and pull it thru your lines and call it a day.
Mike
rattleNsmoke is offline   Reply With Quote
Old 11-03-2012, 05:02 PM   #26
Winterizing
This is our first winter with our Rockwood Roo. 2013 - 23RS.
I did the antifreeze method and did get some in the FW Tank, hopefully there is no aftertaste in the spring.
The Roo will remain plugged in through the winter so we're leaving the batteries on the tongue.
I was wondering if anyone has thoughts on raising the tires off of the ground. the trailer will be parked in my driveway, but we have heard that the tires can get flat spots.
2007 Chevy TB LS, 4.6, 3.42 //
2013 Forest River Rockwood Roo 23RS
ZedSher is offline   Reply With Quote
Old 11-03-2012, 06:27 PM   #27
j2detroit's Avatar
We live up here in northwest man were -30 is not uncommon for low temps not to mension windchills I have blown out the lines in our camper for 4 years now using a gallon of pink stuff to pour into drains in sink shower and stool that's it easy as can be
j2detroit is offline   Reply With Quote
Old 11-04-2012, 06:19 PM   #28
cogito ergo moo
Cowracer's Avatar
oilless-schmoiless. I use my old crappy 2hp barrel-tank compressor. I regulate it down to 30 or so PSI. You can put a filter on it if you insist, but I just hook up and go.
Tim
FROG Member MO-0008-571 Since 20124444444444My Project Blog: https://cowracer.blogspot.com/
2016
Rockwood Signature Ultralite 8329ss
Rallies Attended:
Cowracer is offline   Reply With Quote
