Old 07-01-2019, 07:16 PM   #1
Blue back lit light switches
The blue back lit light switches are very bright and drain on the battery. Anyone know how to shut them off??
Battery fully charged at bedtime and dead by morning.
Whatís drawing so much current?
LadyCanuck is offline   Reply With Quote
Old 07-01-2019, 07:21 PM   #2
Are you running your refrigerator on 12 VDC? That's the most common battery killer.
johnbryanpeters is offline   Reply With Quote
Old 07-01-2019, 07:46 PM   #3
Blue led lights draw very little juice.
Big users are, cpaps, heater, fridge, any inverter item.
Keep looking.
A voltmeter on your battery is a good plan. Fancy battery monitors are good.
tomkatb is offline   Reply With Quote
Old 07-01-2019, 08:37 PM   #4
bikendan's Avatar
Not true.
Only popup and truck campers have 3-way fridges that have a 12v option.
2-way fridges only use 12v DC to ignite the propane side. They use very little battery power.
The biggest battery killer is the furnace.
Equalizer WDH
Old 07-02-2019, 01:29 PM   #5
rlh1957's Avatar
You can get little dot stickers that are varying darkness to cover over clock, television, switches and components that emit led lights to brightly into a dark room. You can still see there is a power light, but it really cuts that annoying light. The LED lights don't consume that much power when being used. If you have an led that stays on 24/7 for a couple months it could draw the battery down. You can replace an LED lit switch for a plain switch, but it defeats the purpose of the lit switch that it's on. Or use one of the stick on dots that is really dark or solid. I used LightDims Variety Pack Light Dimming Sheets. has precut dots as well as custom pieces to cut. This is a non adhesive window cling stuff so no mess, can be easily removed, but won't just fall off.
2018 Forest River Rockwood Roo
24WS
2019 Ford SD F-350 SRW Lariat
Tow & Gooseneck Prep
FX4 Off Road (4X4)
rlh1957 is offline   Reply With Quote
Old 07-02-2019, 01:41 PM   #6
cherokeebill's Avatar
I agree that these little leds don't use much power however they are annoying at night. In our 19FD E-pro the control panel faces the bed. The lights are annoying so we shut them off. Problem solved.
2018 E-Pro towed by 2019 Jeep Cherokee Limited
cherokeebill is offline   Reply With Quote
Old 07-02-2019, 02:35 PM   #7
rlh1957's Avatar
Do you have just one battery? How old is it? Battery may have issues. Take it out and have it load tested to determine if listed amp hours match the test results.
Is the radio or TV or other device on? Just the little bit of electric for fridge ignition isn't enough, nor are led lights. Do you have your phones plugged in to usb chargers, laptops pulling USB or 12V power, was the furnace fan run? Testing the current draw tells you how much is going out, then you have to start turning off things till you find the culprit.
24WS
FX4 Off Road (4X4)
Old 07-02-2019, 05:30 PM   #8
The back lit switches are lighted with an LED. Maximum current drain is in the neighborhood of under 0.020 amps, pretty much negligible for practical purposes. The only way to conveniently turn them off would be to pull the fuses for the circuits the switches operate.
Were the RV mine and I wanted to decrease brightness, I would insert additional resistance in the lead the goes directly to the LED in question. Generally 800 to 1000 ohms will dim it a bit, while still keeping the light functional. The only practical way to dim LEDs that I know of is to use a pulse width modulated dimmer. These are available cheaply on eBay and Amazon, but I believe it will entail far more technical work than most RVers want to endure.
Photo Lab is offline   Reply With Quote
Old 07-02-2019, 06:30 PM   #9
Usually Confused Member
emm-dee's Avatar
Most lighted switches have three wires. Pop the switch out and remove one of the end (usually) wires and no more lights keeping y’all awake.
2018 Forester 3051S (aka Clyde)
2015 Wrangler Toad (aka Bonnie)
At some point during every day you suddenly realize nothing else productive is going to happen the rest of that day. For me, it usually occurs around 9 am.
emm-dee is online now   Reply With Quote
Old 07-02-2019, 06:40 PM   #10
What 12v items are you using that are drawing that much current?
Some residential refrigerators utilize an inverter (powered by 12v) to make the 120v current necessary to keep them running. They consume a good deal of current.
Some refrigerators are 12v compressor type such as the EverChill models. They too use a good bit of 12v current.
Some LP refrigerators have heating elements in the door(s) to keep condensation off. They can use a good bit of 12v current.
The furnace is another 12v power hog.
Propane/CO detectors use some too as well as radios or sound bars.
Ceiling vent fans can consume additional 12v especially when on high.
Led lights and lighted switches use little current.
What size battery do you have and what condition is it in? What are you using to recharge it?
Days Camped: '16=46 '17=30 '18=51 '19=36
light, switch
