Old 06-16-2017, 02:23 PM   #21
Originally Posted by aeblank View Post
I live on an up north (to some people anyway) seasonal road. Where you at?
Who, me? Sitting at my computer replying to a post. If you read my avitar you'll see where I'm at....
I own property in Northern Michigan near Big Rapids however.
SidecarFlip is offline   Reply With Quote
Old 06-16-2017, 02:27 PM   #22
Originally Posted by SidecarFlip View Post
Who, me?
I'm an hour north, in Cadillac.
I looked at your profile, it was useless for this.
aeblank is offline   Reply With Quote
Old 06-16-2017, 02:34 PM   #23
You are looking in the wrong place. Look to the left of this post...Says, SE Michigan.
Old 06-16-2017, 02:42 PM   #24
It was useless to figure out where your "up north" property is.
Old 07-08-2017, 09:09 PM   #25
i have a 12v outlet in bedroom. my older winnie came with one. on our newer 2014 georgetown 377, I had to access the 12v wires under the front of the bed and installed 12v with 2 usb. on my winnie with one coach battery, i used a 150 watt inverter and lasted easily overnight.
good luck
jrowe0521 is offline   Reply With Quote
Old 07-08-2017, 09:25 PM   #26
Puzzlme
Puzzlme's Avatar
Yes, I ended up buying a 150 watt pure sine inverter. It runs the CPAP as well as an oscillating fan all night not problems.
https://rhodaventure.com/
2013 Sunseeker 3010DS
2014 - 15,000 Kilometers (9360 Miles) Alberta through the US to E. coast, up into Atlantic Canada, Newfoundland and back.
2015 - 2 great trips so far. Alberta to Oregon coast, Alberta to Shushwap in BC.
Puzzlme is offline   Reply With Quote
Old 07-14-2017, 09:12 PM   #27
2010 Georgetown
I belong to a cpap forum and there are a lot of threads there on how to camp and do cpap.
Short answers:
All cpap machines have power supplies that drop voltage to dc. Several machines are designed to operate off of 12 volts. those are easy, runn them off of a battery.
If not, then you can run them off of an inverter.
The choices then are either a deep cycle battery, or if you need less weight, you can build a lithium (newer type no fire threat).
Personally, I plan to use my existing rv aux batteries, and run an inverter. My machines run on 19 volts....
Ted Wilson
Now in Alaska, hpope to be in Dallas Texas sometime
1992 Rockwood (33 foot)
TST 507 TPMS
wilsonintexas is offline   Reply With Quote
Old 07-14-2017, 09:44 PM   #28
How many amps? Up converters are cheap enough.
Old 07-15-2017, 09:12 AM   #29
My machine is 12V. We will test it out for 3 nights this week, hopefully without needing a recharge of the battery. I think the most obvious upgrade to start with would be to get a second deep cell battery. I will research/start a new thread about whether matching batteries is important.
I'm learning a great deal here.
gptraveler is offline   Reply With Quote
Old 07-15-2017, 10:43 AM   #30
Matching batteries is important (size, brand, age).
That said, I'm using a horribly mismatched pair and it's fine. Just know it isn't optimal and one or both will die early. For me, once I have a better charger, I'll get a set of Trojans.
