Old 05-17-2014, 09:22 PM   #1
Puzzlme's Avatar
Boondocking with a CPAP device.
Just wondering if anyone has a solution to running a CPAP medical device while camped without power? I'm taking a month this summer to travel in my motor home. I'm a complete newbie but I'm thinking I'm probably not the only one traveling with this type of device. What do you use to power yours? Looking for tips, not looking forward to sleeping without it.
Puzzlme is offline   Reply With Quote
Old 05-17-2014, 09:32 PM   #2
B and B's Avatar
Hi,
My unit has a 12 volt cord available for it. Use your coach battery, not start battery, to power overnight. The humidifier will draw a lot more current, I would recommend you avoid its use.I have 2 machines and the newer res,Ed one draws half the power of the older one.
Brian
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
B and B is online now   Reply With Quote
Old 05-17-2014, 09:39 PM   #3
BamaBob's Avatar
6 Actual (DW) uses one (Icon model with humidifier) And she can use the whole unit on the battery pack they have. Only problem is they are expensive. I agree with B&B - see if you can get a 12V cord but you will have to go without the humidifier I believe
Nights Camped: 2013 - 24 2014 - 42 2015 - 56 Jul 2016 - Fulltime
BamaBob is offline   Reply With Quote
Old 05-17-2014, 09:39 PM   #4
Denver, CO
garbonz's Avatar
get an inverter, an extra battery, and a battery monitor and you should be okay.. how many amps goes the CPAP draw? From what I can tell it can be from about 1.5 amps without a humidifier to 5 or so amps. an 80 am deep cycle should be enough for one night assuming max draw, up to several night at the lower amp draws.
2017 Fuse 23T
Old 05-17-2014, 09:50 PM   #5
I believe the older (5 yrs) ResMed are 12v, BUT to run on battery (cigarette lighter socket), they are wired with the center as negative which is just the opposite of normal. Ask me how I know after burning out fuses 2x. Finally they revealed their dirty little secret.
Old 05-17-2014, 10:39 PM   #6
PPST OGCDG
Frank-VA's Avatar
ResMed S9 CPAP Battery Pack
Frank- VA {:-{)
2004 4x4 Ford 6.0 PS, SCC, SB
2005 Wildcat 29 RLBS
Frank-VA is offline   Reply With Quote
Old 05-17-2014, 11:09 PM   #7
Pitstop88's Avatar
I'm a respiratory therapist and I just want to commend you guys for being so faithful about wearing your cpap. Way to go!
Jeff and Kathy Howard
2013 Rockwood Ultra Lite 2703SS
2011 Chevy Silverado 2500
Pitstop88 is offline   Reply With Quote
Old 05-17-2014, 11:38 PM   #8
rbq
We traveled around Alaska for 1 1/2 week in a rented motorhome. I have a 12 volt plug that I plugged into the 12 volt outlet in the motorhome. I filled the humidifier, but didn't turn it on due to the power draw. It worked fine. Just had to be sure & remove the tank before travelling.
For use in our tent trailer and now in our hybrid I have used an AGM battery that I got from Cabellas. Last year I decided to wire in a 12 volt outlet below my bed where I had previously used the AGM battery. It works fine using my 6 volt battery setup on the coach. Just have to watch the battery level & charge with generator when it starts to get low. Just can't sleep without the CPAP. Gotta have it!
2001 Chevy Silverado
2011 Rockwood Roo 233S
rbq is offline   Reply With Quote
Old 05-17-2014, 11:40 PM   #9
SKnight's Avatar
I've got three and soon to be four group 27 Interstate deep cycles feeding an inverter, When I get a chance I'm going to measure the actual amp draw on the line to see what I should be able to expect with regard to duration. I considered the 12V version, but my therapist made me feel like they were troublesome so I went with a regular Fisher Pykel Icon.
Old 05-18-2014, 02:34 PM   #10
Puzzlme's Avatar
Thanks.
I should be able to sleep like a baby.
