04-20-2015, 10:18 PM
Boosting RV parks Wifi signal , can it be done with plug in booster
Ok where our seasonal spot is we have free Wifi but the signal is weak . Question is can we buy a signal booster and plug it into one of our outlets in the 5th wheel and boost the strength from a couple bars to maybe more . I see boosters on line but will it make signal stronger is question .
04-20-2015, 10:28 PM
Hello, I have a Aped Wireless that works well. I just put the one antenna up near the small window in the Fiver.
Amped Wireless TAP-EX High Power Touch Screen Wi-Fi Range Extender
Easy to configure with a touch screen.
B and B
04-20-2015, 10:33 PM
I have a Netgear booster that just plugs in. It is a bit of a pain to set up, especially if you are moving around. Also, I think their support is lacking.
That said, it does work and has helped us in a number of poor reception situations. It might solve your problem for around $70. You should put it at the end of the RV that is closest to their hot spot.
04-20-2015, 10:34 PM
Thanks that's what I thought but wanted to make sure before wasting money
04-20-2015, 10:44 PM
I have a friend that was successfully using a booster. After I found the Netgear one, I asked him what he had been using. Same one, so I bought it.
It is a WN1000RP.
04-21-2015, 12:12 AM
Phat Phrog Stunt Crew
I use a Jefatech booster on my RV. It has 1/2 mile or 1 mile range outside antenna. I've had good luck the last two months with it in a campground where the wifi is weak.
You can find info at JEFA Tech
2014 Wildcat 327ck
04-21-2015, 11:51 AM
Which Jefatech
Thanks for the link, which one did you purchase? Was it just a repeater or what?
04-21-2015, 12:50 PM
Do these have a monthly charge after initial cost?
I have Verizon jet pack ... But cost per month
How much data do most of you carry
04-21-2015, 01:27 PM
Originally Posted by B and B
Does this work in campgrounds with hotspot wifi?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
04-21-2015, 01:39 PM
Yes, I used it at the only KOA I have been in, worked well. Easier to connect all of your own devices to it. Used at Goshen last year and it work fine till the Internet caved in due to usage. I have tried it at home and found lots of unsecured signals and repeated them as well.
B and B
04-21-2015, 01:43 PM
At a Good Sam's campout last month I think I found the single best solution to WIFI/3G/4G signal boosting out there. The park we were at did not have WIFI, but one of the guys camping with us was tapped in to the free WIFI at a Hardee's restaurant 3.5 MILES away (and before the WIFI police respond, YES he had gone to Hardees, bought lunch and asked permission from the manager )
Still, he told me that in parks with so-so signals or at crowded rallies his Thewirie (that's the name of the booster) brings in WIFI to his unit with zero issues. The unit he has will also boost your cell reception and he said when he was out west in the boondock of Utah he could get 2-3 bars when everyone else had no service.
Problem is you *really* need to have a need for good WIFI/Cell signal, because the unit is NOT cheap ($650 ). It mounts on your whaletail and provides a turnkey WIFI hot spot inside your RV.
www.thewirie.com
Nights Camped: 2013 - 24 • 2014 - 42 • 2015 - 56 • Jul 2016 - Fulltime •
04-21-2015, 01:45 PM
[QUOTE=B and B;841951]Used at Goshen last year and it work fine till the Internet caved in due to usage. QUOTE]
Yeah Brian I wonder how the internet is gonna be at Goshen THIS year?? Wonder if a Thewirie would help in THAT situation
04-21-2015, 01:48 PM
Thanks B and B where did you get yours from? Now that future shop is belly up, guess Best Buy or Staples?
2014 Forester 3051s
2012 Sonic toad
04-21-2015, 02:27 PM
JEFA Tech: Long Range WiFi Repeater Kit for RVs
I use the long range repeater by Jefatech. The kit is $170 and operates all my devices on one sign in from the campground WIFI. The first year at Goshen I had steady wifi with 350 campers. Last year it was hit and miss with over 500 campers. Better than others. This year ???
When the fairground wifi dies I turned to Verizon Jet Pack for internet.
2014 Wildcat 327ck
04-21-2015, 02:40 PM
Plus 1 on JEFA Tech Repeater:
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
04-21-2015, 03:32 PM
The Ubiquiti Nanostation Loco M2 works very well. Mounts on a pole outside. One CAT5 cable to your computer or wireless router. $50.
04-21-2015, 03:37 PM
We use the amped Wi-Fi repeater as well and it works great on most campgrounds. As stated put it near a window face the office or wifi access point.
Orval and Yvonne
2016 Flagstaff 27RLWS Emerald Package
2011 F150 SCrew XTR 5.0L 4x4
04-21-2015, 03:48 PM
Canada Computers on line is good source. We have a store in Waterloo. Tiger Direct is also closing down retail as well, I guess the "Show-rooming" is killing all electronic retailers.
Brian
B and B
04-21-2015, 03:52 PM
[QUOTE=HSVBamaBob;841955]
There must some open WiFi somewhere. hmmmm
We could try these guys...
Copper Wireless LLC - Residential Internet Service
They have a 30 day satisfaction garantee
B and B
04-21-2015, 03:58 PM
Brian
We have one here in Ajax also, thanks for the tip
2014 Forester 3051s
2012 Sonic toad
