Old 04-21-2015, 11:30 PM   #21
We have a booster and it helps somewhat. We were in a Good Sam park and after 6 pm when people are streaming videos it was useless. Had to wait until most went to bed to use the internet. At my sisters we are camped 100 feet away from her modem and it works great.
Mookie is offline   Reply With Quote
Old 04-22-2015, 08:39 AM   #22
miatared's Avatar
I have the Ubiquity Nanostation Loco M2Click image for larger version
Name:	ImageUploadedByForest River Forums1429709802.260710.jpg
ID:	74924, with a long CAT5 cable and I stick it to the best window inside as we camp on different CG. Under $70. Works like a charm.
Denis & Diane
2010 Sabre 31REDS
Ford F-250 2011
* Happy Campers *
miatared is offline   Reply With Quote
Old 04-22-2015, 12:30 PM   #23
Anders's Avatar
We have used Alfa wifi booster for years and it works well.
Anders Cortes Island, BC. Canada
Pony: 2017 Dodge 3500 Longhorn 4x4, Quad Cab
Harness: Hijacker 24-AS-18 Autoslide, Demco Glide Ride Pin Box
Chuckwagon: 2011 Rockwood 8265WS
Travel Blog
Anders is offline   Reply With Quote
Old 04-23-2015, 02:22 PM   #24
Jefa Tech
Originally Posted by ourflat View Post
Plus 1 on JEFA Tech Repeater:
Frank
I'm looking at the Jefa Tech. I like how you installed the antenna on the TV antenna. What about the cable, how did you get in on the inside. I know from research they said not to use a regular coax cable.
I'm assuming you are happy with the results you are getting from the repeater?
vibe is offline   Reply With Quote
Old 04-23-2015, 02:31 PM   #25
ourflat's Avatar
The JEFA Tech kit will come with the cable. I asked for the 259 connector not to be installed so I could cut the length to my needs. I ordered mine through their customer service folks and told them what I wanted. As you can see from the picture, I ran the coax cable through the same location as my awning lights and awning motor cables. My repeater is awesome and I can pickup WIFI signals from other sources up to a 1/2 mile away from me. I haven't been in a park yet where I couldn't pick up their signal. I'm installing a Wilson 4G cell phone repeater next!
Frank
Frank
2016 Days Camping so Far: 24
2013 3051S Forester
2013 Elantra GT (Toad)
WashU EMBA "39
ourflat is offline   Reply With Quote
Old 05-07-2015, 09:43 AM   #26
Has anyone installed their own wireless network with their on SSID and encryption, that can connect to the campground wifi as a bridge? I'd like to install some local devices like appleTV or raspberry pi's for some simple automations (temp, lights, etc.) but don't want to have them all directly connected to the local wifi. I will look into the range extenders and see if any of them have this capability, but thought I'd ask here too.
alfista is offline   Reply With Quote
Old 05-07-2015, 10:02 AM   #27
vinmaker's Avatar
But are you wired to it? It almost looks like you have to hook up a USB cord from the unit to the laptop. How would one use this for an ipod, ipad, or phone?
Just curious.
Vin.
2015 HW296
2006 HW256 (previous pup)
2013 Chevy Tahoe
Equalizer WDH 1000#
Old 05-07-2015, 12:19 PM   #28
Phat Phrog Stunt Crew
elind's Avatar
When I installed the jefa on my TT, I attached the antenna to the TV ant and run the cable thru the bedroom vent. Then I mounted wifi router on the TV bracket and powered it from the TV power plug. On my 5er I mounted the antenna on my ladder, run the wire down the the ladder and then drilled a hole under the entertainment center to put it a cabinet. It's a wireless router so it works all thru the camper.
elind is online now   Reply With Quote
Old 05-07-2015, 02:56 PM   #29
I use the Ubiquiti Nanostation Loco M2 on a pole, point it at the access point. Connect it to an Apple router via a length of CAT 5, and then can connect all of our devices wirelessly to the router as you desire. Can also be done with a Linksys if you upgrade the firmware.
See....
MartyQ is offline   Reply With Quote
Old 05-08-2015, 08:07 AM   #30
reading thru this thread got me to thinking... remember the good old days when you went camping to UNPLUG from everything and experience nature? now it seems like we really want to take it all with us. the TV in my camper usually only comes on if it's a rainy movie day. diff strokes for diff folks tho, it's all good.
steveh326 is offline   Reply With Quote
