Old 04-20-2015, 10:18 PM   #1
14 CC 38CK's Avatar
Boosting RV parks Wifi signal , can it be done with plug in booster
Ok where our seasonal spot is we have free Wifi but the signal is weak . Question is can we buy a signal booster and plug it into one of our outlets in the 5th wheel and boost the strength from a couple bars to maybe more . I see boosters on line but will it make signal stronger is question .
14 CC 38CK is offline   Reply With Quote
Old 04-20-2015, 10:28 PM   #2
B and B's Avatar
Hello, I have a Aped Wireless that works well. I just put the one antenna up near the small window in the Fiver.
Amped Wireless TAP-EX High Power Touch Screen Wi-Fi Range Extender
Easy to configure with a touch screen.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 04-20-2015, 10:33 PM   #3
coupevillefish's Avatar
I have a Netgear booster that just plugs in. It is a bit of a pain to set up, especially if you are moving around. Also, I think their support is lacking.
That said, it does work and has helped us in a number of poor reception situations. It might solve your problem for around $70. You should put it at the end of the RV that is closest to their hot spot.
coupevillefish is offline   Reply With Quote
Old 04-20-2015, 10:34 PM   #4
14 CC 38CK's Avatar
Thanks that's what I thought but wanted to make sure before wasting money
Old 04-20-2015, 10:44 PM   #5
I have a friend that was successfully using a booster. After I found the Netgear one, I asked him what he had been using. Same one, so I bought it.
It is a WN1000RP.
Old 04-21-2015, 12:12 AM   #6
Phat Phrog Stunt Crew
elind's Avatar
I use a Jefatech booster on my RV. It has 1/2 mile or 1 mile range outside antenna. I've had good luck the last two months with it in a campground where the wifi is weak.
You can find info at JEFA Tech
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 04-21-2015, 11:51 AM   #7
Which Jefatech
Thanks for the link, which one did you purchase? Was it just a repeater or what?
vibe is offline   Reply With Quote
Old 04-21-2015, 12:50 PM   #8
psgrandpa1's Avatar
Do these have a monthly charge after initial cost?
I have Verizon jet pack ... But cost per month
How much data do most of you carry
psgrandpa1 is offline   Reply With Quote
Old 04-21-2015, 01:27 PM   #9
Does this work in campgrounds with hotspot wifi?
2014 Forester 3051s
2016 Nissan Pathfinder SL
2012 Sonic toad
wana65stang is offline   Reply With Quote
Old 04-21-2015, 01:39 PM   #10
B and B's Avatar
Yes, I used it at the only KOA I have been in, worked well. Easier to connect all of your own devices to it. Used at Goshen last year and it work fine till the Internet caved in due to usage. I have tried it at home and found lots of unsecured signals and repeated them as well.
