Every time I press the blue tooth button on the GT-3.0 all I get is "BT ERROR" message on the screen. Any suggestions on how to correct this and get the blue tooth wording again? Thanks, Doug
I did try to reset the system, but no luck. Also turned off power to the whole coach and then turned back on with no luck. I will try removing the fuse. Thanks
Are you putting your phone, ipad or whatever you are connecting via bluetooth into the pair search mode before you hit the BT button?
I have not been impressed. The bluetooth is for sound only. You cannot link up and send video It is fine for sending Pandora from your phone if you like though.
Ed
2015 Rockwood 8289WS
2009 Ford F-250
FYI: The user manual can be found at the following link. It does not address a "BT Error" from what I can see, but does give the steps for connecting via BlueTooth". http://manuals.heartlandowners.org/m...11.26.2011.pdf
