Old 09-10-2009, 09:08 PM   #11
for all the tips. I believe I will pin the plug until I can make my own tube/holder to mount underneath.
kphammer is offline   Reply With Quote
Old 09-11-2009, 05:44 AM   #12
gregm59 , what brand of ladder do you have that fits in the bumper. That would make it handy to take with you in case you needed a ladder
jim&dianne73 is offline   Reply With Quote
Old 09-11-2009, 12:24 PM   #13
gregm59's Avatar
Hi,
Here is the link. This one is one sided and if I bought another one, I'd get the step ladder version. It's great to get up high enough to brush off the slide and it's even useful around the house. It's quite sturdy. I got it on sale for around $50.
http://www.campingworld.com/shopping...g-ladder/20320
Greg
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 09-11-2009, 08:32 PM   #14
Originally Posted by cat1956 View Post
Had these on my TrailManor. PERFECT!
dano 2 is offline   Reply With Quote
Old 05-07-2010, 04:42 PM   #15
I go to Wally World and buy a small picture hanging chain cut it put one end on the bumper with a screw and the other end fastened to the cover.
It looks real good. .
Olratlr is offline   Reply With Quote
Old 05-08-2010, 04:11 PM   #16
I like the retaining clip made out of the welding rod. Its simple and easy to reproduce. I have access to welding rod and will make a couple of them up. I like the E-Z-Hose Carrier. I've seen pumping contractors with PVC pipe with threaded end caps, I'm going to look at some pumping supplies and see if I can make one for less money.
2603@orchard is offline   Reply With Quote
Old 06-06-2010, 08:52 AM   #17
Cunning Linguist
Originally Posted by milzat View Post
Radio is right.
Don't store your sewer hose in the bumper. The vibration from the trailer movement will wear down the plastic coating on the outside of the hose.
Mount one or two of these E-Z Hose Carrier under your trailer, or where ever. Cap closes securely and is vented for evaporation.
Work great.
Just installed this & it works great.
I also bought a set of hinged bumper plugs & installed those (they run like $4.00), so I can now store my fishing rods in the bumper.
In addition to the easier access from the covers, the mounting hardware prevents them from coming out.
Acara is offline   Reply With Quote
Old 07-19-2010, 10:38 PM   #18
Mr. Black's Avatar
I cut out two 4x4 inch squares of 1/8" plate steel, I then took a holesaw and cut 1.25" holes in the squares for ventilation. I welded a heavy hinge to each square plate end cap. I welded the hinge to the bumper lining up the squares with the bumper ends. I then welded a tab inside the bumber. I cut a slot in the end cap door to mate up with the tab. I then keep them closed with a hitch pin. In the left side of the bumper I welded in a stop so the poop tube can't migrate to the other side of the bumper. The right side I didn't use a hitch pin, I used a cotter pin and bent it up tight. No reason to open that one really.
It turned out awesome and as strange as it sounds I get lots of compliments. Sorry I didn't take any pictures at this time.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 07-27-2010, 10:40 PM   #19
Easy fix
Get a small diameter tent spike and drill a hole through the top and bottom of the bumper and plug. Slide the tent spike through the bumper and plug and it's fixed. The tent spike is smaller than a 1/4 inch and has a turn at the top that rests on the top of the bumper.
Kstalvey is offline   Reply With Quote
Old 07-27-2010, 10:52 PM   #20
Lightbulb
Originally Posted by Hokiehall View Post
I saw an article in Trailer Life about that. Drill about a 1/4" hole on both sides of the bumper and both ends.Run a 12" zip tie through the holes and wrap around the cap and snap together. This will require a new zip tie each time you have to access the hose, but they are relatively cheap.
Actually you can get reusable wire tires from NAPA.
Store Locator | NAPA Online
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
