Old 07-27-2010, 10:55 PM   #21
Thanks Guys...lots of good ideas......
I had seen Milzat's bumper work beofre and been thinking on going that route.
2011 Wildwood 27BHSS
2007 Sub 5.3L 3:73
Hot DW
1 Princess & 2 Busy Boys
Ventura County, CA
Willie is offline   Reply With Quote
Old 07-27-2010, 11:19 PM   #22
Since my hose wouldn't fit in the bumper, I got some leftover sewer pipe from a friend (copied his work), bought the necessary fittings & mounted the holder on top of the bumper. Looks very similiar to the E-Z Hose Carrier.
2017 Chevrolet K2500HD, Husky W/D hitch
2009 Rockwood 2106 Mini-Lite
Nights camped 2010: 21
Nights camped 2011: 17
Nights camped 2012: 8
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
Old 08-07-2010, 11:30 AM   #23
Here is my solution. I ordered 2 stainless steel "quick pins" and 2 stainless steel with plastic covered lanyards. I drilled a hole trough the bumper and cover so the pin slides through and the catch ball locks. I drilled a hole high enough not to interfere with the hose coming in and out and used an aluminum pop rivet to hold the lanyard in place. If I loose the plug, the pin still holds the hoses in the bumper. I can't drop and loose the pin as it is hooked to the bumper. The bumper plug still works as designed so if I forget to put the pin in it still works as intended. Total cost from Amazon.com including shipping was $18.02.
ID:	3082   Click image for larger version
ID:	3083   Click image for larger version
ID:	3084   Click image for larger version
Kirk, KN1B
2013 Cardinal 3800FL
2009 GMC 3500HD CC LB SRW
kbrown1075 is offline   Reply With Quote
Old 08-07-2010, 11:44 AM   #24
4" sewer pipe...project cost less than $25 in parts. IMHO, bumper is a bad place to store the stinky slinky... it's thin wall and rusts like crazy. Not what you want when you have a spare tire / etc clamped to the bumper.
Name:	DSCN0806 (Large).jpg
2010 Rockwood 8281SS Signature Ultra Light
2009 Dodge Ram 2500 w/6.7 Cummins
bobsquarepants is offline   Reply With Quote
Old 08-07-2010, 03:28 PM   #25
MrT
MrT's Avatar
Originally Posted by milzat View Post
I made a retaining pin using a Heliarc welding rod, bent into the shape below.
Wait until my wife hears that I need a Heliarc welder...
2017 Cedar Creek 38CK Hathaway Edition
2015 Ford F-350 6.7 CC 4x4
B&W RVK3300
Full-timing since 5/2/2016. Roam Sweet Home.
FROG Int'l Rallies: 2012-2017
MrT is offline   Reply With Quote
