Old 09-07-2009, 08:37 PM   #1
Bumper plugs
Any advice how to keep the 4 inch square bumpers in place? Tired of replacing them and losing my hoses on the highway.
kphammer is offline   Reply With Quote
Old 09-07-2009, 08:52 PM   #2
I saw an article in Trailer Life about that. Drill about a 1/4" hole on both sides of the bumper and both ends.Run a 12" zip tie through the holes and wrap around the cap and snap together. This will require a new zip tie each time you have to access the hose, but they are relatively cheap.
I have two sewer caps that can be attached to the bumper by screws and have a hinged door that opens. Bought them at camping world.
Hokiehall is offline   Reply With Quote
Old 09-07-2009, 08:56 PM   #3
Velcro strips have been on mine for 3rd summer without trouble. I tied a string around the end of the hose to grab and pull out the hose. Good luck !
Mickey
Mickey is offline   Reply With Quote
Old 09-07-2009, 09:47 PM   #4
cat1956's Avatar
http://www.campingworld.com/shopping...mper-plug/6902
cat1956 is offline   Reply With Quote
Old 09-08-2009, 11:57 AM   #5
gregm59's Avatar
I lost one of the locking bumper plugs on the first trip out. With the plug installed, I drilled a hole thru the top and bottom of the bumper, making sure to drill thru the plug, and dropped a 5" threaded bolt thru and put a wing nut on the bottom. Since I store a collapsible ladder in there, I wanted to make sure it could not get out.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 09-08-2009, 04:13 PM   #6
donjuanss's Avatar
You can also drill and then use the clips like you use on your load leveler springs the spring clips and then put them in the hole.
U.S. Army Retired Desert Shield/Storm Vet
2014 Silverado Crew Cab
2009 28ft Flagstaff V-Lite
1996 Impala SS 1972 Chevelle SS
donjuanss is offline   Reply With Quote
Old 09-08-2009, 04:25 PM   #7
Are ya'll having them fall out while on the road or losing due to forgetting to put them back in?
I was thinking about drilling a hole thru the corner diagonally and putting a pin in it myself.
edman87k5 is offline   Reply With Quote
Old 09-08-2009, 08:30 PM   #8
milzat's Avatar
I made a retaining pin using a Heliarc welding rod, bent into the shape below.
Drilled a hole through the bumper and cap.
Worked great.
milzat is offline   Reply With Quote
Old 09-08-2009, 08:49 PM   #9
Cyber Phrenologist
Radio's Avatar
I just don't like putting the hose back in the bumper "wet" so I generally toss the washed out hose into the pickup bed. The hose gets proper storage once we get home or to the next stop. We camp mostly in state parks so the hose usually gets used only at dump stations.
The problem is, I leave the bumper plug sitting on top of the bumper. If I could just remember to put the stupid plug back in the bumper then I'd be alright.
Just senile, I guess.
KU4OJ
2008 (or is it 2009?) Rockwood 8280SS - 2022 F-250 7.3L
Radio is offline   Reply With Quote
Old 09-09-2009, 08:14 PM   #10
milzat's Avatar
Radio is right.
Don't store your sewer hose in the bumper. The vibration from the trailer movement will wear down the plastic coating on the outside of the hose.
Mount one or two of these E-Z Hose Carrier under your trailer, or where ever. Cap closes securely and is vented for evaporation.
Work great.
Old 09-10-2009, 09:08 PM   #11
for all the tips. I believe I will pin the plug until I can make my own tube/holder to mount underneath.
Old 09-11-2009, 05:44 AM   #12
gregm59 , what brand of ladder do you have that fits in the bumper. That would make it handy to take with you in case you needed a ladder
jim&dianne73 is offline   Reply With Quote
Old 09-11-2009, 12:24 PM   #13
gregm59's Avatar
Hi,
Here is the link. This one is one sided and if I bought another one, I'd get the step ladder version. It's great to get up high enough to brush off the slide and it's even useful around the house. It's quite sturdy. I got it on sale for around $50.
http://www.campingworld.com/shopping...g-ladder/20320
Greg
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
Old 09-11-2009, 08:32 PM   #14
Originally Posted by cat1956 View Post
Had these on my TrailManor. PERFECT!
dano 2 is offline   Reply With Quote
Old 05-07-2010, 04:42 PM   #15
I go to Wally World and buy a small picture hanging chain cut it put one end on the bumper with a screw and the other end fastened to the cover.
It looks real good. .
Olratlr is offline   Reply With Quote
Old 05-08-2010, 04:11 PM   #16
I like the retaining clip made out of the welding rod. Its simple and easy to reproduce. I have access to welding rod and will make a couple of them up. I like the E-Z-Hose Carrier. I've seen pumping contractors with PVC pipe with threaded end caps, I'm going to look at some pumping supplies and see if I can make one for less money.
2603@orchard is offline   Reply With Quote
Old 06-06-2010, 08:52 AM   #17
Cunning Linguist
Originally Posted by milzat View Post
Radio is right.
Work great.
Just installed this & it works great.
I also bought a set of hinged bumper plugs & installed those (they run like $4.00), so I can now store my fishing rods in the bumper.
In addition to the easier access from the covers, the mounting hardware prevents them from coming out.
Acara is offline   Reply With Quote
Old 07-19-2010, 10:38 PM   #18
Mr. Black's Avatar
I cut out two 4x4 inch squares of 1/8" plate steel, I then took a holesaw and cut 1.25" holes in the squares for ventilation. I welded a heavy hinge to each square plate end cap. I welded the hinge to the bumper lining up the squares with the bumper ends. I then welded a tab inside the bumber. I cut a slot in the end cap door to mate up with the tab. I then keep them closed with a hitch pin. In the left side of the bumper I welded in a stop so the poop tube can't migrate to the other side of the bumper. The right side I didn't use a hitch pin, I used a cotter pin and bent it up tight. No reason to open that one really.
It turned out awesome and as strange as it sounds I get lots of compliments. Sorry I didn't take any pictures at this time.
Steve
1999 Ford Superduty F250 PSD CC SB 6spd 4x4.
B&W goosneck/companion hitch, Airlift 5000 airbags.
2006 Sierra F28 Rear Kitchen 5th Wheel, 31' = 10k pounds.
Nights camped in 09-14, 2010-23
Mr. Black is offline   Reply With Quote
Old 07-27-2010, 10:40 PM   #19
Easy fix
Get a small diameter tent spike and drill a hole through the top and bottom of the bumper and plug. Slide the tent spike through the bumper and plug and it's fixed. The tent spike is smaller than a 1/4 inch and has a turn at the top that rests on the top of the bumper.
Kstalvey is offline   Reply With Quote
Old 07-27-2010, 10:52 PM   #20
Lightbulb
Actually you can get reusable wire tires from NAPA.
Store Locator | NAPA Online
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
https://inlinethumb45.webshots.com/3...600x600Q85.jpg
revrnd is offline   Reply With Quote
