Old 11-02-2014, 04:34 AM   #1
paulmac's Avatar
Bypass Valves - Location......why?
Am I the only one who wonders why they locate the bypass valves in such difficult places to get too? In our flagstaff they are behind a panel next to the toilet in the bathroom. To get to them you have to first extend the slide out a little so you can get to the bathroom located in the rear of the coach. Remove the access panel located near toilet and low to the floor, so you have to get on your hands and knees. Then bend over even further to see and access the valves. This is right near the hot water heater. Why couldn't those valves have been placed on the outside of the coach just above the hot water heater behind a locked access panel? Or in the hot water heater compartment? And I have seen or heard of bypass valves placed in worse locations. Appears to me people who design the coaches never think about small things like this. Don't get me started on the location of the dump valves for the grey and black water on this camper
paulmac is offline   Reply With Quote
Old 11-02-2014, 07:18 AM   #2
nosaint3
The first day I hooked up to the campground water on my trilogy we had water but no hot water. We found the shut off valve by climbing into the storage area and opening the panel next to the water shut off system and with a looky feely system got the shutoff valve turned on for hot water.
nosaint3 is offline   Reply With Quote
Old 11-02-2014, 07:55 AM   #3
mcnabbwr's Avatar
It is no different than any other product it's done for space savings and cost. If the engineering departments worked on any product in the field I believe they would make changes. I won't mention make or model, but remember several years ago if you wanted to change a spark plug in this car you needed to remove the motor mounts to jack the engine up or cut the inner fender well.
Bill & Pam
2014 Trilogy 3650RE
2015 F350 PSD
mcnabbwr is offline   Reply With Quote
Old 11-02-2014, 10:58 AM   #4
And it's not just the bypass valves. On my trailer, the low point drains are behind the dual wheels. No way to reach without lying on the ground and crawling underneath.
Jerry
2007 Surveyor SV 230
2013 F150 Ecoboost
azjerry is offline   Reply With Quote
Old 11-02-2014, 11:50 AM   #5
davel1971's Avatar
if that's your only "problem" with your camper, consider yourself lucky
David & Lynn
Old 11-04-2014, 06:46 PM   #6
Boss Hoss's Avatar
And while we're at it-why would F.R. put the fresh water drain-dead center under my TT.I now have an elbow extension to the edge of the trailer.WHAT WERE THEY THINKING????
2013 Palomino 30ft. of Pure Bliss at 5400#-and then we have this 14 ft.Sea Eagle that I tote around for my wife and son.Michigan State Parks are The Best !:thumbsup
Boss Hoss is offline   Reply With Quote
Old 11-04-2014, 07:15 PM   #7
Ford Idaho's Avatar
Is that a trick question.............
Old 11-04-2014, 07:50 PM   #8
VinceU's Avatar
Need to realize the people building sub assemblies like furniture and pump/ water heater skids never see the "line" or he finished products. Their job is to build sub assemblies and have no idea how they are shoe horned in.
Old 11-04-2014, 08:00 PM   #9
Twisty's Avatar
Slam and jam and get them out the door!!
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 11-04-2014, 08:58 PM   #10
davel1971's Avatar
because that's where the tank is and water doesn't drain uphill
David & Lynn
bypass, cat, location, valve
