Old 10-06-2017, 05:44 PM   #1
ADK
Camp Power Checker
I made myself a quick campground power checker. The idea is to hop out of the truck and do a quick check to see if it looks like a good choice.
2017 F-150 XLT EcoBoost 3.5 Crew Cab 4x4
2018 Rockwood #8328BS
ADK is offline   Reply With Quote
Old 10-08-2017, 09:48 AM   #2
SeaDog's Avatar
Interesting. I use my plug in surge protector for that.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
Old 10-08-2017, 12:11 PM   #3
ADK
I am probably going to do the hardwired surge protector. I didn't want to invest in the portable model and then buy a hardwired later. New trailer was built last week and is somewhere between here and there. Still waiting.
Old 10-12-2017, 08:24 AM   #4
Handyman
Why the double meters?
2016 Salem Cruise Lite 253RLXL
2013 F-150 XLT 5.0 Crew Cab
2009 F-150 King Ranch 5.4 Crew Cab
tfmdgm is offline   Reply With Quote
Old 10-12-2017, 08:29 AM   #5
wmtire's Avatar
If it's a 50 amp outlet, you have two legs/lines to check for.
You can go to this site, and click on the outlet testing tab on the left, and see how to design these plug-n-play testers with the links at the bottom of that page. I have one for a 30 amp and use it every time. I have an analog volt meter, but do like the digital ones the OP is using better. ADK did an excellent job with his.
RV Electric
Edit: Here is direct link for 50 amp tester form the site above:
http://www.myrv.us/electric/Pg/tester_50amp.htm
and 30 amp tester which is much simpler to put together
http://www.myrv.us/electric/Pg/tester_30amp.htm
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 10-12-2017, 08:33 AM   #6
One thing that this won't tell you is if the 50 Amp service is using both legs of the 230 Volt service. If the outlet is wired to present only one leg to both prongs then you would expect to see what is in the picture. Identical voltages on both legs. At my home the voltage difference between the legs is always several volts due to load imbalances in the neighborhood and my home. The way to tell if it is a 50 Amp circuit is to measure between the two legs for 220-240 Volts which when split to the neutral would be two 110-120 volt legs.
2018 Rockwood 2509S Mini Lite
Past: 1984 Road Ranger 20', 1988 Kit Companion
1984 Starcraft 24 foot popup
TV: 1999 Dodge 2500 Cummins 4x4
Honda EU2000i Generator, 200 Watts Solar
Ham Callsign KD7UM
UT_Grandpa is offline   Reply With Quote
Old 10-12-2017, 08:43 AM   #7
wmtire's Avatar
I understand what you are getting at UT_Grandpa, however if you will click on the 50 amp outlet tester tab I linked to above, you will see in the instructions how they put in a light/circuit tester for just the scenario you are describing.
The OP can easily add this to his tester, if needed/applicable.
Old 10-12-2017, 10:16 AM   #8
The Neon tester tells the truth.
Nice circuit. Very simple. Thanks
Ham Callsign KD7UM
Old 10-12-2017, 11:27 AM   #9
ADK
Left box is line L1 and right box is L2, its a 50 amp plug. If I have my shop lights on one leg is 1 volt less usually.
Old 10-12-2017, 11:41 AM   #10
Handyman
When I looked at it I was thinking 30 amp. That’s why I questioned the double meters.
Old 10-15-2017, 07:56 AM   #11
paulmac's Avatar
Same here, and I also use a plug in digital voltage meter that is always plugged in an outlet of the camper. And since it has a "blue glow" to it makes a decent night light.
paulmac is offline   Reply With Quote
check, power
