Old 11-05-2009, 10:13 PM   #1
Send a message via AIM to pjeffreysr1
Can't get the pump to draw antifreeze
Ok, maybe I am not Einstein, but when I winterized our 'late pup' I had no problem getting the very noisy pump to pick up the antifreeze. Just finished the install of the winterization kit on the new Wildwood 26bhxl, but I can not get it to pic up the antifreeze. Checked all the fitings, re-tightened all - including the little "filter screen" housing. Still won't pull antifreeze. What the heck am I doing wrong? On the plus side, the "SHURFLO" pump is so quiet I have to listen HARD to hear it run.
pjeffreysr1 is offline   Reply With Quote
Old 11-05-2009, 11:18 PM   #2
If it won't suck the antifreeze, then it's sucking air somewhere. Explain what the winterization kit is, and how you installed it, may help us help you. Should be a valve to stop suction from fresh water supply and divert to a hose stuck in the antifreeze jug. Must still be sucking from fresh water tank.
LadyWindrider
2012 Ford F250 ext. Cab 4x4
2002 Jeep Wrangler Sahara
2008 Work and Play 18LT
Old 11-06-2009, 12:17 AM   #3
Also make sure your hose is not too long that you stick in the jug of antifreeze
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
Old 11-06-2009, 12:41 AM   #4
Kit is just a 2 way valve (draws from the inlet the handle is pointed to). The hose is maybe 3 ft long (max). Gonna try again later today (it is 12:40 am here) Probably take everything apart and reassemble with tef-tape just to make sure not air leaks.
Old 11-06-2009, 12:51 AM   #5
Did you have any faucets open when you were trying this. I had the same problem, but when I went inside and opened the bathroom faucet, it started pumping. Maybe an air lock on the water system, or something. It worked for me. Good Luck.
2008 Wildcat 32QBBS, 99 F350 Dually CC 4X4 Powerstroke.
670johndeere is offline   Reply With Quote
Old 11-06-2009, 12:34 PM   #6
MtnGuy's Avatar
Something might be wrong with the pump. I haven't heard of a Shurflo yet that was quiet. The hose for pulling the antifreeze is usually right beside the pump, so you gotta hear that puppy.
Old 11-07-2009, 11:13 PM   #7
Welllll! Let's just say that putting the valve in the right way really helps :-/ A LOT. I had it backwards. :-(. As for the noise - who parked that diesel in the pump compartment. One upcoming mode: an "air tank" - at least 2 gallon size. That "puppy" sounded worse than my old boxer when he was asleep - LOUD.
antifreeze
