Old 04-27-2011, 11:24 AM   #1
carbon monoxide sensor
Last weekend , setup the popup to clean and grease for the up coming summer . Had to charge up the battery. the secound day when i got up to close everthing up . found the C.M. sensor was on so checked everthing and made sure the tank was turned off. had to pull out the breaker to get it to stop.
today ( three days later ) the sensor was on again!. could this be to the battery going down? ....... and I want to thank everbody for the ideas on how to fix my tail light , got it working 8-)....
skip1955 is offline   Reply With Quote
Old 04-27-2011, 11:31 AM   #2
gregm59's Avatar
It could be the battery. It also could be the sensor. We had one go bad after about 5 years. If you have a meter, you can check your battery when the sensor is going off.
2007 Surveyor SV291
Equil-I-zer hitch
2005 Durango Hemi
gregm59 is offline   Reply With Quote
Old 04-27-2011, 02:06 PM   #3
Thanks, The rig is almost a year old. But it has sit for almost 3 mnts. Had to recharge up the battery to raise the top. take care ....92 and sunny at 3.79 a gallon in Harlingen, TX
Old 04-27-2011, 02:11 PM   #4
Herk7769's Avatar
Leaving a battery dead for 3 months could ruin it. I would have it removed to a shop that can do the right tests on it.
HAM CALLSIGN - KC3FFW
Old 04-27-2011, 05:48 PM   #5
ruin the battery ? or the sensor ?
Old 04-27-2011, 08:32 PM   #6
Herk7769's Avatar
Sorry, the battery.
Old 05-07-2011, 04:43 PM   #7
Our sensor on our Cherokee 27L went bad after about 3 years, similar symptoms as yours.
stevenmacc is offline   Reply With Quote
