Old 09-04-2016, 03:02 PM   #1
Charcoal Lighting Tips
Propane Torch does the trick
pbandrb is offline   Reply With Quote
Old 09-04-2016, 03:30 PM   #2
Phenom's Avatar
That's pretty slick.
I just use a chimney. I put a page or three from a newspaper in the bottom and coals on top. Light the paper and it's a done deal. Then after grilling I pour the left over hot coals in the fire pit and layer my smaller wood over it. My campfire pretty much lights itself.
Sean
'16 28DBUD
'16 2500HD Dmax
Phenom is offline   Reply With Quote
Old 09-04-2016, 03:40 PM   #3
Wobbles's Avatar
So, you are in a hurry and you are cooking with charcoal?
I carry that torch but not for cooking...
Bob & Michelle
2016 Ford F-250 Lariat 4x4
2017 Flagstaff Super Lite 526RLWS
Wobbles is offline   Reply With Quote
Old 09-04-2016, 04:10 PM   #4
Chimney works as well but i did not have one with us
Old 09-04-2016, 04:12 PM   #5
the no lighter fluid taste is better, but don't tell DW in a hurry, she asked me is that SAFE
Old 10-20-2016, 08:41 PM   #6
What's a newspaper?
Pam & John in WI
PamJohnZephyr is offline   Reply With Quote
Old 02-18-2017, 06:01 PM   #7
Put a small propane burner under your chimney and it will get going even faster. I did a lot of cooking at large events and we always had burners running under the chimneys to keep us going with hot coals for what ever we needed dutch ovens or grills
Jmkjr72 is offline   Reply With Quote
Old 02-18-2017, 06:30 PM   #8
Georgia Rally Coordinator
aceinspp's Avatar
I use a chimney and then use two cubes of Weber starter. Works great . No more using Charcoal lighter fluid. Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
Old 02-18-2017, 06:33 PM   #9
SailorSam20500's Avatar
I've often started camp fires the same way..
A favorite story about a buddy of mine:
Before I start, let me say that the main character has been an active scout leader for years. All three of his boys made Eagle. So, they SHOULD have lit a camp fire or two over the years...
Anyway, the oldest son decided to have a big party with several other guys that he was renting a house with. They are out in the country - so little worry about ticking off the neighbors. This is early fall, so it was getting a bit cool in the evening. The day before, they piled up a big pile of wood for what was to be a bon-fire. That night and the next day, it rained...
So, when they go to light the fire, it doesn't. Then my buddy takes control (under the watchful eye of his 3 Eagle scouts). Dumps a quart or so of gasoline onto the pile of wood. Puts the gas can down well away from the pile of wood then walks back and tosses a match into the woodpile.
WHOOOSHHHH!!! The fumes from the gas had spread out around the file to a distance of about 10 feet! Flames singed his ankles!
His wife about had a heart attack!
Needless to say, I will never let him live it down!
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 04-14-2017, 09:31 PM   #10
OLDNAVY's Avatar
I use a chimney with 2-3 Fritos or Doritos. Can also use toilet paper core with oiled cotton balls, or dryer lint
OLDNAVY is offline   Reply With Quote
Old 04-14-2017, 09:58 PM   #11
tuckerdog1's Avatar
I put vegetable oil on a couple paper towels. Put them in the BBQ ( leave a bit exposed so you can get a match to it ). Pile on the charcoal & light the paper towels.
Tuckerdog1
2016 RAM 2500 Cummins SLT Lone Star 4X4 LB
2016 Windjammer 3029W Platinum
I'm not an expert. But I play one on the internet.
You live & learn or you don't live long.
If you don't punish your children, life will.
tuckerdog1 is offline   Reply With Quote
Old 04-29-2017, 03:42 AM   #12
Kenz's Avatar
I use an electric charcoal starter. Basically an electric element that you pile charcoal on it, plug it in, 5 minutes later the charcoal is lit.
2011 Coachmen North Ridge 290RKD 5'er
2005 Dodge quad cab dually diesel 6'spd manual
1 weird cat with an occasional attitude problem.
Kenz is offline   Reply With Quote
Old 05-05-2017, 10:45 AM   #13
Sewgratefulquilts's Avatar
Simple and Cheap
I pour rubbing alcohol over cotton balls at home. Seal them up and then at when needing to light the charcoal, tuck a few under the charcoal. Gives a long enough burn for the charcoal to light.
Sewgratefulquilts is offline   Reply With Quote
Old 06-20-2017, 10:44 AM   #14
That is a good idea
light
