Old 06-24-2017, 11:34 AM   #1
miniceptor86's Avatar
Cheap crank mod
I don't mind cranking down the stabilizers by hand but I did not like the supplied crank rod sooo... I had a couple of braces as in brace and bit that I found at a garage sale (2 for $3.00). I cut off the offset of the original crank rod, flatten the end a little so the brace could get purchase and VIOLA! I have a nice to operate crank.
ID:	142590   Click image for larger version
Cheers, Jim and Sandy
'14 F150 FX4, '15 Coachmen FE29SE
miniceptor86 is offline   Reply With Quote
Old 06-24-2017, 11:37 AM   #2
fonzie's Avatar
For an upgrade later, you could get a battery operated drill......nice mod
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 06-24-2017, 03:53 PM   #3
Thanks,
I have a cordless drill, but every time I want to use it the battery needs recharging. Plus the manual method burns some calories at gets the blood moving.
Old 06-24-2017, 04:25 PM   #4
Just a member
kandl's Avatar
Nice mod! After going through three stabilizer motors in just over a year, I gave up and have been manually laboring ever since. The motors were painfully slow anyway.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
Old 06-25-2017, 06:08 AM   #5
Thanks kandl
