Old 09-15-2013, 06:52 AM   #11
acadianbob's Avatar
Originally Posted by garbonz View Post
Rotochoks do it all and the small change in "diameter" with temperature is insignificant for the rotochoks. They lamp firmly and don"t need adjusting, no rachet or anything else. Once level side to side , set the roto's and forget em. First on and las toff.
X2. And you can always use Rotochoks on the both sides; even if you have used lego blocks to raise one side.
But they don't work with widely separated axles.
2018 F250 Lariat 6.2 4X4 w 4.30s, 2018 Wildcat 29RLX
2003 Yamaha FJR1300, Demco Premiere Slider
Red Green coffee mugs
Old 09-15-2013, 09:07 AM   #12
Denver, CO
garbonz's Avatar
Yeppers, You can get them pretty wide but there is a limit. I think they are well worth the price both for convenience and safety.. The hard plastic wedge pieces REALLY grip the tires. IMO
2017 Fuse 23T
Old 09-15-2013, 04:00 PM   #13
Oklahoma Proud
MillerTime's Avatar
I just kick the chocks in, the plastic wedges hold pretty tight. If parking on boards, I may drive a couple of 16 penny nails in behind the chocks for a little extra.
Old 09-15-2013, 04:26 PM   #14
Originally Posted by wrvond View Post
...Between the wheel chocks rely strictly on friction to hold the wheels in place. As the temperature of the tires change due to cooling (after being pulled in) or air temperature change, the tire diameter decreases, reducing the effectiveness of the between the wheel chock considerably. These things are good for stabilization, but to rely on them to keep the camper from rolling is a mistake.
I have used the Bal X Chocks for 7 years now and on more than 1 occasion have forgotten to remove them before attempting to move the trailer and cannot budge the trailer with them installed. Have never had to tighten them due to temperature changes or a tire diameter decrease. I use them as a pull test to make sure the hitch is secured. First thing installed after parking and last thing removed before leaving.
Old 09-16-2013, 10:54 AM   #15
Stg1's Avatar
I use the BAL Deluxe Chocks They were the original chocks(before the X chocks). I've used them since 2004. with no issues, I do occasionally check them to make sure they remain tight. I see no reason to not rely on them to secure the wheels.
Steve and Marlene and 2 Furry Kids. LB (Maltese) Rocky (Border Terrier)
2013 Coachmen Catalina 25RKS 2006 Nissan Titan Crew Cab
Stg1 is offline   Reply With Quote
Old 09-16-2013, 07:42 PM   #16
Professional Curmudgeon
Glad they are working well for you. Others, besides myself, have noted that they needed to tighten both the Bal X's and Roto Chocks after the tires cool down. Still others have had them spit out and allow the camper to roll (one rolled into a tree, bending the bumper).
It is possible that in all the cases I have read about, the users had the wrong size, or simply didn't install them correctly. Nothing is beyond the ability of man to mess up.
On my last camper, I used a pair of yellow plastic wedges that didn't use a tool to tighten (I wouldn't expect plastic to stand up to that kind of pressure). They were pretty effective at reducing rocking, but that's all I would trust them for.
2002 Forest River Flagstaff 8528RLS
2014 Coachmen Catalina 253RKS
2016 Keystone Summerland Mini 1750RD
2012 F250 Lariat 6.2L Crew Cab FX4
wrvond is offline   Reply With Quote
Old 09-16-2013, 07:50 PM   #17
All I can say is evidently they were not tightened correctly when installed initially if they required attention after cooling. Kinda like changing a tire and leaving the lugnuts loose and then griping when the wheel falls off.
Old 09-16-2013, 08:34 PM   #18
Denver, CO
garbonz's Avatar
X22222.. Glad you said it before I did.
2017 Fuse 23T
Old 09-16-2013, 08:36 PM   #19
Phat Phrog Stunt Crew
elind's Avatar
I have the E Z tow wide axles on my Lacrosse. The Bal X chocks are pricey compared to close axle X chocks. So i made my own for less than $20 out of 2x4s and threaded rods. It does the job for a tenth of the cost.
2014 Wildcat 327ck
elind is online now   Reply With Quote
Old 09-16-2013, 08:40 PM   #20
elind's Avatar
X Chocks
Name:	july 2013 052.jpg
2014 Wildcat 327ck
