Old 09-16-2013, 08:42 PM   #21
Originally Posted by elind View Post
I have the E Z tow wide axles on my Lacrosse. The Bal X chocks are pricey compared to close axle X chocks. So i made my own for less than $20 out of 2x4s and threaded rods. It does the job for a tenth of the cost.
I would have done the same out of 4 x 4's, but was in Weslaco, TX at the time and Camping World had them on special for $39/pr. As usual, couldn't wait so I bought them. Best $39 + tax I've spent as far as a safety/stability solution.
Old 09-16-2013, 10:17 PM   #22
Phat Phrog Stunt Crew
elind's Avatar
I could only find X Chocks for the wide spaced axles at $79 + shipping each or about $200 with shipping a set. I took 2x4s, glued & screwed to create 4x4 ends where the threaded rod goes thru to tighten them up. Think of adding another 2x4 to give it a 4x6 ends against the tires.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 09-17-2013, 02:12 PM   #23
Denise1950's Avatar
We've been looking at the BAL x-chocks and they seem to get a lot of good reviews. Do you use these in addition to plastic or rubber chocks, or to replace them? Also, does it make a lot of difference whether you put them on both sides?
2008 Rockwood 8313SS
2007 Z71 Silverado 5.3 Liter V8 w/tow package
Denise1950 is offline   Reply With Quote
Old 09-17-2013, 06:48 PM   #24
elind's Avatar
I use both X chocks and the tire wedges. The wedges to park the RV and then the X chocks on both sides to stabilize the RV.
2014 Wildcat 327ck
Old 09-17-2013, 06:53 PM   #25
Use them on both sides and don't use any other chocks of any kind. Haven't had a need for additional chocking.
Old 09-17-2013, 08:57 PM   #26
BurgPath's Avatar
I started with the plastic yellow Walmart ones we used on our popup. Then I bought the BAL roto chocks for between the tires. I recently purchased the hard rubber Harbor Freight ones.
Next trip I'll use the rubber ones and the BAL chocks. Overkill? Even if so I'll stick with it.
Kevin (BurgPath)
2018 Grand Design Reflection 337RLS
2017 Ford F350 CCSB
Mods and Pics
BurgPath is offline   Reply With Quote
Old 09-17-2013, 09:10 PM   #27
You are the only one that has to be satisfied with how you chock your trailer regardless of what others do. Do it the way you like and forget what others do unless you think they have a better way.
Old 09-18-2013, 06:46 AM   #28
DF5.4's Avatar
I have used the yellow plastic chock and rubber mallet method for years. Never had a problem. Earlier this year I noticed an "expiration date" molded into the plastic.
Doug
2011 Prime Time Tracer 3000BHS
2007 Ford Expedition
Reese Dual Cam HP Hitch
Nights Camped 2015-5 in TT
DF5.4 is offline   Reply With Quote
Old 09-18-2013, 08:44 AM   #29
Ford Idaho's Avatar
Say what!
I know UV light rays are hard on plastic but an expiration date......
