Old 08-16-2013, 11:52 PM   #1
Chock technique... thoughts?
I am curious what others might think of a technique I have been using this summer. I am using the plastic wedge chocks and this is on relatively level sites.
I get situated/level and put a chock up tight behind the front tire of the trailer, then put the truck in reverse and just put some pressure on the chock, then while still applying the pressure, my wife will slide another chock in front of the tire. Let the pressure off and the tire is wedged between the two chocks. My thought is this might achieve some of the desired effect of one-step or even a x-chock. What do you think?
lvnthenw is offline   Reply With Quote
Old 08-17-2013, 12:05 AM   #2
Twisty's Avatar
After leveling side to side, I use one of these on each side;
Amazon.com: BAL 28020 Single Axle Tire Chock: Automotive
Our next TT will have 16" rims so I may need to have a longer turnbuckle built to fit.
You should be able to find a much lower price.
I wouldn't ask my wife to do what you have your wife do.
FOR SALE 2014 BOSS 6.2L F350
2012 Surveyor SV264
NW Oregon
Twisty is offline   Reply With Quote
Old 08-17-2013, 12:08 AM   #3
Wife
Sometimes if she isn't available I can do it by putting on the E-brake and doing it myself. A lot of the time she is guiding me into a spot so she is right there. Were you suggesting that it's dangerous?
Old 08-17-2013, 12:24 AM   #4
Twisty's Avatar
I'm not picking at what you do or nit picking what you do.
I wouldn't do it.
Plastic chocks might slip. I don't know for a fact that they do or can but they look like they might.
I've done a lot of rigging and heavy moving. We use rubber and metal goods.
A slipping chock could spook or injure someone. Sometimes the injury happens because of a spook - loss of balance, panic reflex, a "knee jerk reaction", etc.
I don't let my wife near the 12,000 lb plus setup that we run until I know that to the best of my ability and knowledge it will stay put.
2012 Surveyor SV264
NW Oregon
Old 08-17-2013, 03:14 PM   #5
bikendan's Avatar
to expect just plastic wedge chocks, to keep the trailer from moving, is an accident waiting to happen.
wedge chocks are only good for a temporary use, until you can get a tandem wheel chock in on BOTH sides.
unless you have a single axle and then you need to get BAL's single axle chock setup.
Equalizer WDH
Old 08-17-2013, 03:54 PM   #6
markb5900's Avatar
We are new TT owners, can see some of my other posts for what not to do. LOL
As for chocking. I go with the rule, they are the first things on the tires and the last thing off.
We get it in and level. Then use chocks on both sides.
Once they are in, then I unhook from the truck.
So far, no issues. I don't put any pressure on them with the truck at all. I just push then up tight to the tire.
Mark B
2015 32 Foot Rockwood 8289WS 5th Wheel
2017 GMC 3/4 Ton TV
markb5900 is offline   Reply With Quote
Old 09-14-2013, 10:31 PM   #7
Professional Curmudgeon
wrvond's Avatar
The method you are referring to has been practiced since long before x-chocks or any other between the wheel chocking system was marketed and I know for a fact I had a TT with this method specified by the manufacturer as the preferred method of securing the TT in place. Between the wheel chocks rely strictly on friction to hold the wheels in place. As the temperature of the tires change due to cooling (after being pulled in) or air temperature change, the tire diameter decreases, reducing the effectiveness of the between the wheel chock considerably. These things are good for stabilization, but to rely on them to keep the camper from rolling is a mistake.
While plastic chocks are not my preferred material, because exposure to UV makes them brittle, the weight of the tire pressing down on the leading edge of the wedge is what holds it in place. I understand you are not endorsing driving the wheels "up onto" the chock, but simply putting pressure on it, then letting it roll forward onto the front chock, thereby getting them tighter than you could by banging on them with a mallet.
Personally though, I would put rearward pressure on the back chock, set the parking brake, put it in park, then set the forward chock myself, then put the truck in neutral and release the parking brake. Easing off the foot brake will allow the wheels to settle into the center of the chocks without "shocking" the setup.
2014 Coachmen Catalina 253RKS
2017 F350 6.7L DRW CC LB 4x4 Lariat
wrvond is offline   Reply With Quote
Old 09-14-2013, 11:07 PM   #8
Denver, CO
garbonz's Avatar
Rotochoks do it all and the small change in "diameter" with temperature is insignificant for the rotochoks. They lamp firmly and don"t need adjusting, no rachet or anything else. Once level side to side , set the roto's and forget em. First on and las toff.
2017 Fuse 23T
Old 09-14-2013, 11:32 PM   #9
simplyrwc's Avatar
I use a single chock on each side. Have only been out a few times but seem to work well. (Don't mind the flat it's fixed)
2004 V10 4X4 Excursion
2014 FR Wildwood 32BHDS
2013 Days Camped 14
simplyrwc is offline   Reply With Quote
Old 09-15-2013, 03:53 AM   #10
Just a member
kandl's Avatar
Yep, that'll achieve some of the desired affect but there are hazards associated with the technique as has been identified by some of your responders. I employ only two rubber chocks (not a fan of the plastic variety) and typically set them on one side or the other depending the terrain. Once we're level, the x-chocks go in and they do indeed work as advertised and eliminates the hassle of wedging the wheels between the chocks to prevent the unit from rocking.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge Ram 3500
kandl is offline   Reply With Quote
