Old 03-21-2014, 07:30 PM   #11
iowaborn's Avatar
Send a message via AIM to iowaborn
Originally Posted by trackhoe59 View Post
What is the best way to get bugs off the front of your 5th wheel?
After washing I have used dryer sheets. They actually do remove the bug remains without harming the finish.
2013 F-250 CrewCab 6.7 PowerStroke 4X4
2017 Silverback 33RK
iowaborn is offline   Reply With Quote
Old 03-21-2014, 08:14 PM   #12
kerrlakelover's Avatar
Remember Grandma saying an ounce of prevention is worth a poud of cure?
Last year a friend of mine told me that when he goes on long trips he sprays slicone across the front of his car. It prevents the bugs from sticking so bad and then they wash off easily. I've tried it a couple of times and it does seem to work. You'll still have an occassional stubborn one. Just spray a light coat across the entire surface.
North Carolina born and bred
2010 Sandpiper 345RET
2011 2500 Duramax Silverado
2001 Centurion Elite Bowrider direct drive
"Old water skier"
Jesus Christ my Saviour
kerrlakelover is offline   Reply With Quote
Old 03-22-2014, 07:43 AM   #13
I don't know if silicone has a solvent properties, probably not. Being a pilot for thirty years, and aircraft wing leading edge catches every bug in its path. Many pilots have great success with Pledge furniture polish. Same concept, spray on, wipe off as if doing furniture. Slippery as can be. Many pilots thought it increased speed due to decreased parasitic drag. Debateable. But it did work well for bugs
Poper is offline   Reply With Quote
Old 03-22-2014, 01:40 PM   #14
trackhoe59's Avatar
Thanks for the reply on how to get the bugs off my RV I will try them
trackhoe59 is offline   Reply With Quote
Old 03-22-2014, 02:44 PM   #15
Phat Phrog Stunt Crew
elind's Avatar
I used Super Clean (Walmart) and brushed on both sides of the awning, rolled it up over night, and then used a Mr. Clean Magic Eraser. I rinsed it and let it dry. This did the job for me.
2014 Wildcat 327ck
elind is offline   Reply With Quote
Old 03-22-2014, 03:02 PM   #16
Originally Posted by Triguy View Post
It really works well. The process I use is to dilute the concentrated Awesome, spray it on the underside (make sure to wear safety goggles and old clothes), climb on top of my camper and spray it on the topside of the awning, roll up awning and let it sit for 30 minutes. Unroll the awning and lightly scrub or wipe off with a mop and water. Rinse top and bottom of the awning with a hose when done cleaning. Let dry.
What ratio of Awesome spray and water did you use 50/50 ????
Flagstaff 8528 ckss fiver
2008 Ford f350 dually 4x4 desiel
racerx is offline   Reply With Quote
Old 03-22-2014, 06:37 PM   #17
Triguy's Avatar
cleaner
7 water to 1 of the Awesome was what I used. Although, I had to spray 100% of the stuff on a really bad corner. I don't think you can go too badly wrong with more Awesome APC. Its non-toxic. There is a list of recommended dilutions on the bottle for various types of cleaning, too.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 03-31-2014, 03:58 PM   #18
Mr.Clean eraser best thing i have ever used on an awning
2003 Dodge Ram 2500 5.9 Diesel
2014 Rockwood 2608WS
Big Paul is offline   Reply With Quote
Old 04-01-2014, 11:44 AM   #19
Capsfloyd's Avatar
On bugs use a fabric softer sheet with a little water ... works great
Sent from my SM-P600 using Forest River Forums mobile app
2009 Rambox crew cab
2012 831 Flagstaff RKSS
2010 jeep Liberty
2010 Harley Davidson Ultra Classic
Capsfloyd is offline   Reply With Quote
Old 04-01-2014, 11:51 AM   #20
Zhanna's Avatar
These are great cleaning tips! Thanks everybody!
2005 Dodge Ram 2500, 4x4
2017 Heritage Glen QBUD312
Zhanna is offline   Reply With Quote
