Old 02-10-2014, 10:32 AM   #11
Wd-40
I do what the Pullrite manual says to do. WD-40 on tubes and everywhere else the manual states to apply a WD-40 like lubricant. Sometimes I wipe a small amount onto the plate, more for corrosion control that anything else. I always wipe it off if I apply it to the plate. Just leave a shinny coat. I try to apply WD-40 every time I hook up when I plan to travel a reasonable distance.
2013 Ford F-350 SD Diesel, 4X4, Crew Cab, Lariat
Sabre 2014 32RCTS, Pullrite Superglide 2900 18K
Davidceder is offline   Reply With Quote
Old 02-10-2014, 12:13 PM   #12
jriddering's Avatar
X2. Do the same on pullrite.
Jim and Carol
2012 Crusader 290RLT
2010 Ford F-250 King Cab Diesel
Harley Davidson Edition
jriddering is offline   Reply With Quote
Old 02-12-2014, 10:22 PM   #13
Ham Radio since 1970
N9ID's Avatar
X3. Keep the plate clean and it will be easier to hook up. Love my Super Glide.
Sent from my GT-P5210 using Forest River Forums mobile app
Mike & Nena Strong
2013 Cedar Creek 36RE
2012 Chevy Silverado Crew Cab 3500HD Diesel 4WD
Nights camped '14: 51 '15: 134 '16: 149 '17: 171
N9ID is offline   Reply With Quote
Old 02-12-2014, 11:09 PM   #14
NELA
Weezer's Avatar
Originally Posted by Ford Idaho View Post
I ask the service manager about them, I ask the guys at my work who use them on their trailers, every one of them said use one.
No they are not for use on every hitch but for those that can use them it is a lot cleaner.
We were told to not use that Teflon plate on our Revolution hitch, said it wasn't needed and wasn't a good idea.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 02-22-2014, 06:49 PM   #15
Working the Life
KD Nolte's Avatar
I have pulling a 5th for about 10 years and have had 3 different Hitch receivers in my trucks, Hitch Hiker and Curt. I have always used a Teflon plate but have been very diligent in making sure it is kept clean. As an extra precaution I have used a dry lubricant on the plate and my hitch receiver.
Any Petroleum based lubricant will attract dirt and reduce its effectiveness.
Be sure to only use non petroleum based lubes on your hitch mechanisms with exception of where you have grease nipples.
KD
2013 Dynamax Trilogy 3800D3 (Feb 2013)
2014 Sierra Denali 3500 DRW
KD Nolte is offline   Reply With Quote
Old 02-22-2014, 07:03 PM   #16
If the Revolution is activated, that is a true statement. However, if the Revolution is locked out or not activated, a Teflon ring should be used.
fifth wheel, wheel
