Old 05-10-2015, 05:00 PM   #11
Cyber Phrenologist
Radio's Avatar
I too have a slide topper but you don't and still need your question answered.
Assuming you have no roof access ladder:
Carry two sections of small rope and a wad of old towels. Tie the towels into a bundle (or wad) in the middle of two 20tf lengths of rope and throw it up onto the slide. Ropes should dangle over each end of the slide. Pull the towels back and forth until you don't see leaves and trash falling off the slide.
The ropes and towels are light, small and have other uses. And you already have them laying around.
If you have a roof access ladder just sweep it off with a broom.
And for those with toppers, wait a year or two and have a look at the slide roof under the topper. Man, where'd all that dust and dirt come from?
Break out the ropes and towels.
KU4OJ
Admin at www.openroadsradio.net, part of the Social Knowledge network.
"RVing and Amateur Radio served up on the same plate"
2008 (or is it 2009?) Rockwood 8280SS - 2007 F-150
Radio is offline   Reply With Quote
Old 05-11-2015, 02:54 PM   #12
I bring alone a folding ladder like the ones sold at Camping World and use a broom to clean the tops of the slides right before bringing then in.
whj77372 is offline   Reply With Quote
Old 05-11-2015, 08:04 PM   #13
dcheatwood's Avatar
I'm on my 3rd RV with slide toppers. Never heard them make any noise in the wind.
A cheaper option is to get a cheap black and decker battery powered blower and attach (tape) an elbow from a vacuum hose to the end and blow leaves off from the ground. Seen it done.
2013 Rockwood 8282WS
Reese Revolution Pin, Reese 16K
2008 Tundra Limited Double Cab 5.7L
Air Lift 5000 w/Wireless Air
Old 05-12-2015, 07:43 PM   #14
Cyber Phrenologist
Radio's Avatar
That would reduce the amount of pooled water, too. And handy for policing the site as well.
KU4OJ
Old 05-12-2015, 08:01 PM   #15
Before a topper I just used the air compressor to blow off the slide. I did use a ladder just to see if there were any "gunk" that needed to be cleaned before pulling it in. If so, I used a wet mop. I've seen folks using the rope and towel method. It works really well even under a topper but takes two people.
rana is offline   Reply With Quote
Old 05-12-2015, 08:18 PM   #16
Cyber Phrenologist
Radio's Avatar
Or one guy a really long time
KU4OJ
Old 05-12-2015, 10:13 PM   #17
dcheatwood's Avatar
If you watch on the highway, you'll occasionally see a stick showing above the slide that got pinched up when closing the slide. I helped a guy get a limb out at the fuel pump once by standing on the steel pole that protects the pump. No damage.
Old 05-13-2015, 08:34 AM   #18
Leaf blower works great for me. Next camper i will order with slide topper
2013 Ram 1500 (5.7)
2014 Rockwood Mini Lite 2104s
http://i307.photobucket.com/albums/n...ps412bc14c.jpg
Prothos is offline   Reply With Quote
Old 05-13-2015, 08:53 AM   #19
We use (Slide Toppers) BUT ,Pine Sap, WET Leaves and Bird Do Do are your Worst Enemies,regardless if you have Toppers or not! The nice thing is the Debris is Not Carried into the unit or Attached to the Top Seals! Youroo!!
Old 05-22-2015, 10:09 PM   #20
paulmac's Avatar
We sweep off the roof before retracting the slide out. Looking into adding a slide topper. Never tried the rope and towel method, might give that a shot.
paulmac is offline   Reply With Quote
slide
