Old 12-11-2018, 08:19 PM   #1
hittheroadgeorge's Avatar
Clogged toilet
We are new to living full time in a rv We recently had our toilet clog It took awhile but it did finally let go.We do put a toilet treatment things in every time we dump Just asking if there is anything better out there to break up the solids and paper? Thanks
hittheroadgeorge is offline   Reply With Quote
Old 12-11-2018, 08:22 PM   #2
Use LOTS of WATER !!!
Decon Blue is offline   Reply With Quote
Old 12-11-2018, 08:30 PM   #3
cavie's Avatar
Do you put about 2-3 gals of water in the tank after dumping? Do you fill the bowl with water before using to poo? Do you keep your gate valve closed until dumping when on sewer??
2011 Keystone Sprinter 323BHS
Port Charlotte Fl/Hinsdale Ma
Retired Master Electrician.
Old 12-11-2018, 08:33 PM   #4
Just as confused as you
Scrapper's Avatar
X2, and do not leave the black water dump valve / termination valve open when you are at a campsite with sewer connection.
Richard & Jill
Camping since 1989, seasonal since 2000
Old 12-11-2018, 08:55 PM   #5
This is the best thing we have ever used. We keep it available and will occasionally cram it down in the toilet and give it a whirl just to make sure stuff is moving along out of there.
merrykalia is offline   Reply With Quote
Old 12-11-2018, 09:58 PM   #6
Yes we were definitely not using enough water We watched a video on how to unclog the toilet and going to try and find the product called Tanktechs RX if I am saying that right Thank you for the tip
Old 12-11-2018, 09:59 PM   #7
Good video Going to get one of those hoses
Old 12-12-2018, 07:48 AM   #8
cavie's Avatar
You are not clogging up any pipes by not using enough water. The tank is directly below or just to the side of the toilet. 3 ' at best. By not using enough water you are causing a POO PILE. The POO is building up and drying out. Not floating around and dissolving. When you dump the water goes away and leaves the pile behind. There chemical tablets that many use are not just for oder. They help dissolve. Just fill the bowl before use and add 3 gal of water after dumping your tank and your problems will go away. Remember, gate valve closed when on sewer.
Old 12-12-2018, 08:35 AM   #9
Your photo shows a class A motor home. These often have a pipe to the toilet, unlike the type that drops straight down found in most trailers. In those it is even more important to use plenty of water to flush.
Cedar Creek Lake, Texas
2017 Wildwood 27 RLSS
2016 Ram 5.7L crewcab, 8 speed transmission
CedarCreekWoody is offline   Reply With Quote
Old 01-19-2019, 06:02 PM   #10
We are not full timers, just sayin', but the rule in our 5er is no poo in the potty and
we don't put the paper in there either....
bmcevers_13 is offline   Reply With Quote
