Old 02-11-2013, 10:10 AM   #1
The Wolfs's Avatar
clothes hangers
We have a nice large wardrobe slide in our Rockwood 2608. I had problems last summer with hangers bouncing off both the rod in the slide and the wardrobe at the back. Any ideas? I really don't want to buy special hangers.
Ken & Ruth
North Central Ohio
2019 Windjammer 3008V
Nights camped 2012-2017 118, 2018 53,
The Wolfs is offline   Reply With Quote
Old 02-11-2013, 10:22 AM   #2
Try a piece of foam pipe insulation. It's slit to go over the rod, easily cut to get the length you need, and when you aren't using it for your hangers put it on the corners of your slides to avoid bangin' your head.
Old 02-11-2013, 11:20 AM   #3
Another solution is to purchase Lynx brand short-necked hangers. The opening for the hanging rod is tight and the hanger has to be pushed onto the rod. They will not slip off like the ones we use at home do. We purchased them at Camping World for about $6 for 6 hangers. Because these are short-necked, they will also add a little extra room below your clothes.
NanaKaren
Karen Elling
2012 Rockwood Mini Lite 2109S
Useta have a 17 ft Casita LD twin bed mod &
Coleman pop up
NanaKaren is offline   Reply With Quote
Old 02-11-2013, 12:12 PM   #4
TURBS's Avatar
Use wire hangers and bend the loop over tight against rod.
Turbs
Old 02-18-2013, 06:14 AM   #5
ret2006's Avatar
Saw these at Camping World. Lynx Stay Put Hangers.
Stay-Put Hangers, 6pk - Tri-lynx Corp 00015 - Laundry Aids - Camping World
2014 Cedar Creek 34 RLSA-7
2015 Chevy Silverado 3500HD LTZ SRW
ret2006 is offline   Reply With Quote
Old 02-18-2013, 01:45 PM   #6
RPAspey's Avatar
we use a $2 spring clamp. Push the clothes to one side and hold in place with clamp. we use clamp to hold towels outside to trees. The clamp looks like the letter "A".
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 04-13-2013, 09:01 AM   #7
Free fix: hook your hangers "backwards" opening pointing toward the door. Don't know why this works but it does, was a tip from my Grandma when we got our TT.
toyota family is offline   Reply With Quote
