09-22-2018, 07:29 AM
Cold forecast
I will be camping in night temps of low 30’s to high 20’s. I have heated underbelly w tank heaters. Any pointers to prevent water line freeze ups?
09-22-2018, 07:37 AM
Need more information- are you on sewer hook ups?
IF YES- then you can open dump valve and leave a tiny trickle running at a faucet.
IF you are not on sewer but are on city water- me-I'd put some water in my tank and disconnect and drain the city water hose at night. Having said that we got up one morning in Tucson and the outside temp was showing 28. My hose did not freeze but I think I was lucky!
Peace!
Dan & Rita D
09-22-2018, 07:53 AM
Aren’t 110 volt heated water lines relatively inexpensive?
For short periods most water tanks have heating pads. Thus draining the water line is easy.
09-22-2018, 07:54 AM
Thanks. Think i ll fill fresh water tank and leave heat and tank heaters on since we will have electricity.
09-22-2018, 07:55 AM
loose the water hose and run of your fresh tank. if you have a 5th wheel put a small electric space heater in the basement.
09-22-2018, 08:01 AM
Sounds good
09-22-2018, 02:00 PM
If ruining a $100 bill is inexpensive in your world
I'm getting ready to do a Fall Trip that will take me through early morning freezing temps, possibly sudden cold while driving.
I have installed some "Pool Noodle" type insulation over the low point drain pipes. A short length held in place with a zip tie above the cap and a piece of foam stuffed in the end. Will also be wrapping some rubber foam pipe insulation tape with aluminum backing on the exposed black and gray water pipes, between edge of heating pad and valve. Tape itself is R-2 but I will double-layer it. 15'x2" Roll of tape was inexpensive at Home Depot. Less than $5. I figure that with the heating pad on the pipe and tank, only the short length of exposed pipe will not freeze with the insulation.
Rather than a $100 heated hose I'll run off the tank and just fill it when it gets low. Will be spending a week in Northern NM at 8,000 feet. All the campground water "faucets" are freeze proof hydrants so filling will be easy even if temp stays below freezing. This approach served me well in a Colorado winter where one AM the window thermometer showed -15 degrees. A good reason to always keep the tank filled if camping during cold weather. Nice to be able to flush the toilet, take a shower, and wash dishes even though it's freezing outside. And then there are campgrounds that DON'T have frost/freeze proof hydrants and just shut off the water when it gets cold. (Butte, MT KOA).
First half the trip will see freezing or near freezing temps. The return leg will, if temps stay close to what they are now, will be 80-100 degrees. Talk about contrasts.
BTW, here's a nice site to get both current and future forecasts for the highways you will be driving:
https://www.theweathernetwork.com/us.../long-term/i-5
Select the highway and look at the forecast for the major reporting stations along it.
09-22-2018, 07:33 PM
THANKS! We are doing the same trip. Appreciate the advice
10-22-2018, 07:36 AM
HI , I'm thinking about doing a hunting / fishing trip to the mountains over the long Thanksgiving weekend + a few days. I'm used to doing this in a tent ,then a popup, now in a ROO 19. My question is, if they turn the water off during freezing temps, do they not also turn the water off at the dump station? If so, how do you dump / rinse the black tanks??
10-22-2018, 08:04 AM
The water will be off at the Dump stations, maybe! Have a bucket and hope you are near the lake! Youroo! !
10-22-2018, 08:24 AM
Well then , I guess I'll have to do what bears do...........
10-22-2018, 08:52 AM
Denver To Yuma In 90 Days
As others have already said...run off of your fresh water tank and be very water conservative so you don't fill your tanks too quickly.
You can dump your tanks without rinsing if you are in a freeze location and do the rinse once you get to a place that is warmer.
Also, only hook up your hose when you need to fill your tank and unhook it once your tank is full!
One other thing...
Keep a very close eye on your outside shower or outside kitchen faucet (if you have them) as they will freeze up and you won't find out about it until the thaw comes!
10-22-2018, 11:08 AM
I "wintered" in a TT during a Denver winter while having a house built. I merely removed the outside shower hose and wand then stuffed the compartment with some fiberglass insulation, closed cover, then sealed with some Duct Tape. There is enough heat leakage from inside into the compartment and the insulation/sealed cover traps enough to keep the faucet head from freezing. Unless you are Finnish or a Laplander there's a slim chance you'll be taking outside showers during freezing weather
10-22-2018, 11:18 AM
That’s a great resource- thanks for sharing it.
10-22-2018, 01:26 PM
In parts of the country with freeze issues they typically use freeze proof water valves. You know when you have to move the long handle 90 degrees.
Not turn the wheel typically.
Usually some sites in a park open year round have the fancy valves. The valve itself is down deep. Any of the regular ones are turned off and winterized.
Most of the campgrounds we were in last summer had the fancy valves.
Like said you can use your heated tank and use a regular hose to fill as necessary.
10-23-2018, 11:01 AM
Thanks for the tip on the outside shower, I had forgotten about that. My main concern was being able to dump the poo tank in freezing weather. I know there's a heater on the fresh water tank, I got off my butt and crawled under the camper and saw where there are heaters on both black and grey tanks as well as on the necks where the valves are. SO there will be no frozen poo waiting on a spring thaw...........
10-23-2018, 11:07 AM
Up in the National Forest , we used to pull water out of the creek to get cleaned up with. You can take a bath in a gallon of water in freezing temps. Thats what we did tent camping up there.yeah it was cold..............
10-23-2018, 11:40 AM
My outside shower is on the very back wall of the 5'ver in a small separate compartment that doesn't have a heating duct near it.
I stuffed it full of insulation and did what I could...but it still froze up.
Of course, when I replaced the faucet I filled that area full of insulation.
However, now that I live in the desert southwest...I'm not too worried about a freeze up anymore.
I still wish that all RV's with outside showers should have assessable shut-off valves on them...
But most don't.
10-23-2018, 01:59 PM
But most don't.
Mine is on the back wall of my TT just below my bathroom sink. No heat duct in bathroom (??) But if I leave vanity cabinet door open it still gets enough heat to keep from freezing. Planning on cutting in some vent "ports" in all the compartments with water lines and equipment.
That way I dont need to remember to open doors when cold.
10-30-2018, 09:15 AM
Rv Living Novice
I am going to make one out of an existing hose and electrical "heat wrap". I bought the CAMCO hose from Amazon and the thing leaked out of the box. None of the pre-made hoses had good reviews.
