Originally Posted by moodog
Very low flame. Using grill hose connected to12 foot hose then to stove regulator and 2 foot hose.
Very little pressure. Connected back to my little bottle and it worked fine. Any suggestions?
Very common. The RV's grill hose is run thru a low pressure regulator, and is designed to work with certain grills that operate off of low pressure. (without a built in pressure regulator)
Most of your other grills, have a pressure regulator built into the grill. So what happens when you connect to the RV's low pressure line, then it's running thru the grills pressure regulator too.... so you in essence have a double regulated low pressure....which is TOO low.
We have several threads on this. You can either adapt your grill (take out it's regulator if possible)....or connect your grill to the RV's propane tanks before it is regulated to the RV's grill hose.
Many people put in a propane distribution T at the tanks, and then run a hose to their grill.
These threads may help:
http://www.forestriverforums.com/for...tml#post708584
http://www.forestriverforums.com/for...ill-87299.html
