Old 04-09-2011, 12:04 PM   #1
Concerns about Geo Method and bleach
As a newbie to the RV / Camping world I have emersed myself into all of the info I can find to try and minimize the likely mistakes I would otherwise make. This thread is specifically about the waste holding tanks not the fresh water tank.
I took great interest in this thread Black and Gray Water Holding Tank Maintenance
about properly maintaining the holding tanks. It sounded like a lot of great info until I got to the part where the author advocates the use of bleach in the holding tank. Now I'm certainly not a chemist, biologist or any other sort of scientist, but I have read that the break down of waste relies on enzymes and bacteria. My immediate concern was- how does the use of bleach effect this process?
What my search found was certainly a contradicting point of view. I didn't find anything that warns against the use of "Water Softner", but the use of bleach in the holding tanks was very much warned against.
A quote "Never use bleach to treat or "sweeten" a tank. Bleach can severely and quickly damage valves, seals, and gaskets"
found at :http://ag.arizona.edu/pubs/water/az1233.pdf
Another author's qoute "There is much controversy over the Charles Bruni method described below. The first thing I will say about it is that I have NEVER used bleach in any of my tanks. The primary reason is that you want healthy bacteria in those tanks and bleach will kill the bacteria"
found here:RV Waste Water Treatment
Guess there are 2 sides to this coin....just food for thought.
flyinguy68 is offline   Reply With Quote
Old 04-09-2011, 12:10 PM   #2
AKA Bluebird
dimurrrw's Avatar
Send a message via Yahoo to dimurrrw
I love it when people actually do some research. IMHO you are right about your concerns. Bleach kills the bacteria and the seals.
dimurrrw is offline   Reply With Quote
Old 04-09-2011, 12:16 PM   #3
Triguy's Avatar
Always seems like a good idea to do your own homework with any advice taken off of the internet. Good job.
Sorry that I have nothing to add to the bleach debate. Interesting research through.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
Old 04-09-2011, 12:46 PM   #4
MtnGuy's Avatar
I even though I use Calgon in my tanks to slicken the sides and probes, I have never used bleach in my black tank, and probably never will. I do use a little bleach in my fresh water tank every spring to sanitize my system, but that is only a 1/2 cup for 30 gallons of water.
Bleach would kill the bacteria in the black tank, maybe leading to less smelly tank, but the odor in mine is easily controlled by a non-formaldehyde deodorizer. Even though the black tank is not a septic tank (where solids are broken down), but instead a holding tank, I figure any breakdown with the solids there can't be a bad thing.
Old 04-09-2011, 01:35 PM   #5
Endersbrab's Avatar
Pages 45 and 46 of my owners manual talks about the holding tanks. It does not endorse using bleach to clean the gray or black water tanks, only to sanitize the fresh water tank.
It states, "do not put automotive antifreeze, household toilet cleaners or drain cleaners, or any solid material into the waste system. Always use chemicals in the black water system that are made especially for this purpose. When cleaning components of the waste water system, use cleaners made for RV systems."
Bleach has it place, but not in the waste tanks According to the owner's manual of course
2012 Flagstaff 23lb Microlite
TV = 2003 Chevy Trailblazer EXT with 5.3 V8
Camper delivered 03-29-2011
Nights camped in 2011 = 17
Nights camped in 2012 = 4, 10 more planned
Endersbrab is offline   Reply With Quote
Old 04-09-2011, 02:31 PM   #6
miatared's Avatar
I guess I missed the part on bleach, never used it, never will for the holding tanks that is.It does not make sense to me either.
My GEO method does not include bleach. I do the Calgon, the clothes detergent and use single ply TP - I dump only when 3/4 to full - no odor and it has worked well to date. And as they say, if it ain't broke don't fix it.
One thing I learned: Fantastic fan must be off when you flush
I remember the days of using the blue chemical, it had that aircraft lavatory smell all the time. Good riddance.
Denis & Diane
* Happy Campers *
miatared is offline   Reply With Quote
Old 04-09-2011, 02:53 PM   #7
MtnGuy's Avatar
I still use the blue deodorizer.....just in case I forget to turn off the fantastic fan before flushing.
Old 04-09-2011, 02:58 PM   #8
Herk7769's Avatar
Wow, I learned that one too! Also don't use the fan when the tank is nearly full. It will be your last warning before the bowl won't empty.
HAM CALLSIGN - KC3FFW
Old 04-09-2011, 05:17 PM   #9
(Kim)
Labzy's Avatar
Ummmm, I'm missing something here
WHAT happens if you have the fan on when you flush????????
2010 Dodge Ram 1500
2012 Rockwood 2306
Kim
DH (Alan), DD (Madison) and Zoey the lab,
Labzy is offline   Reply With Quote
Old 04-09-2011, 05:28 PM   #10
miatared's Avatar
The Fantastic fan lives up to its name and displaces lots of air - if you have it on, even on low speed, and you flush .... well it pulls all the aromas from the black tank, enough to raise the dead
Denis & Diane
* Happy Campers *
