Old 05-22-2013, 09:21 PM   #1
Hybrid_Lvr
Roo5008's Avatar
Concrete block under jack
Just set up my 23ss in the driveway after returning from a camping trip to Delaware. I used a solid 8 inch block then a hollow 4 inch concrete block under the jack and removed the TV. Little while later, bam, the hollow concrete block just exploded and trailer in 4 inches lower than it was. I use wood block while camping but usually use the concrete blocks at the house.
Roo5008 is offline   Reply With Quote
Old 05-22-2013, 09:25 PM   #2
Herk7769's Avatar
I gather you are going to stop using concrete blocks?
HAM CALLSIGN - KC3FFW
Old 05-22-2013, 09:30 PM   #3
You have to set the concrete block the same way it is laid in a footer for a house or wall. You cannot set it on its side. Set it like in a wall with a pc of wood under it and then another pc of wood on top and then jack on the wood.
Old 05-22-2013, 09:43 PM   #4
Professional Texan
TexasBob's Avatar
Even concrete blocks have a weight rating. I had one explode on me several years ago while leveling a mobile home.
Texas Bob
2015 Chevrolet Silverado HD2500 Z71
2013 Prime Time Tracer Executive 2640 RLS
TexasBob is offline   Reply With Quote
Old 05-22-2013, 09:56 PM   #5
I am in materials testing and we test CMU block or Concrete Masonry Units. They are not that strong hollow, if you must use them I would fill the cells with concrete mix or a grout mix. You would be better off throwing a form together and pouring a concrete pad, much stronger. I poured two long pads for my 5th wheel and also had a tongue pad for my previous TT. I made them flush with the gravel, they look nice and you know right where to park your trailer.
MMattox is offline   Reply With Quote
Old 05-23-2013, 09:28 AM   #6
I scrounge new home build sites for my campfire wood. They are more than happy for you to pick through their scrap cuts pile usually out front. I have found some excellant wood pads that I use for my leveling jacks made out of I guess sandwich board ridge beams. Over an inch thick, heavy and I've found lengths as long as six feet of this stuff that I use under the wheels during winter storage. Great stuff and the price is right!
sherman12 and The Fabulous Miss Barb
2014 SportsCoach Cross Country 360DL DP
Former 2011 Georgetown 330TS
Kia Sportage on MasterTow Dolly
sherman12 is offline   Reply With Quote
Old 05-23-2013, 10:10 AM   #7
RPAspey's Avatar
x2 dumpster diving. I live in a active development where a new home is always being built. Plenty of wood for ramps and fire!
2000 Cherokee 29BH with 6V batteries, LED lights & 400 watts of solar power, flipped axles and raised. 2007 Tundra 5.7L DC-LB with lots of mods. C-co, 8/158th AVN Maint.
RPAspey is offline   Reply With Quote
Old 05-27-2013, 08:45 PM   #8
Hybrid_Lvr
Roo5008's Avatar
That is correct sir!
Old 05-28-2013, 04:06 AM   #9
My brother brought a lot of old lumber scraps out to a camp site I had up on Mount Hood in Oregon a couple of years back. He got all ticked off because I would not burn his trash wood in the campground. I guess some of you do not realize that a lot of lumber is treated, has glues in it, etc. not only smells but might be giving off toxic fumes when burned. Kids breathing it in and roasting your marshmallows in toxic fumes.
jamesroadking is offline   Reply With Quote
Old 05-28-2013, 01:56 PM   #10
You certainly do not want to burn OSB, pressure treated lumber, plywood or wood that has paint or stains on it, but kiln dried 2X and 4X's are perfectly fine, in fact they don't have the bad bugs in them either so it is better than transporting your wood from home as the parks are now asking you not to do.
