Old 10-29-2017, 09:14 AM   #1
CarpeDiem's Avatar
Concrete Slab Suggestions
We are thinking about a concrete slab in our back yard for our pop up and a 16” bowrider. We would also have to eventually install a new fence. Right now I just take down two fence panels and move the trailer in and out. The boat is 8’ wide and I think the slab should be big enough to accommodate a larger camper as much as 28’. Anyone have any thoughts pro or con? We live in the Orlando area and the ground is usually pretty soft.
2018 Rockwood Premier 2516G
2014 Nissan Titan
“Always do what’s right; this will gratify some and astonish the rest” – Albert Einstein
CarpeDiem is offline   Reply With Quote
Old 10-29-2017, 09:26 AM   #2
I don't know what you mean by pro's and con's. I mean, you want a concrete pad big enough to store eventually a 28 ft trailer, so just do it. I guess a pro is it is done and accommodates future needs. A con is it is larger than you need today?
Only point I can see, if you currently take down two fence sections to get your trailer in and out, isn't there a post between those two? Is that removable as well?
I say just do it.
Mike
TV = 2017 Ram 3500 (aka FRAM)
5er = SOB (2019 Grand Design Reflection 367BHS)
walaby is online now   Reply With Quote
Old 10-29-2017, 10:30 AM   #3
CarpeDiem's Avatar
We bought the house about two months ago. The fence installer didn’t cement the posts in. So I just pull it out, back the trailer in and resecure the sections. The more I think about it, you are probably right, silly question
2014 Nissan Titan
Old 10-29-2017, 12:12 PM   #4
paulmac's Avatar
About the only thing I would suggest would be to have a 30 amp outlet installed with the slab. I got spoiled when my in-laws were alive. Being campers themselves my father-in-law had an area just off the driveway that you could back the camper in to, and there was a 30 amp plug built into the retaining wall there. Was nice to be able to keep the camper plugged in, or plug it in a few days before a trip.
paulmac is offline   Reply With Quote
