Old 01-08-2015, 08:05 AM   #1
condensation between skylight panels
When putting my 26 foot Puma away for the winter this past Oct. I noticed a problem that is going to have to be addressed when I pull it back out this spring. It seems that condensation has been forming at some time between the outer and inner panels of the shower skylight. There was a little bit of dampness on the interior ceiling around the trim of the skylight, so I pull this piece off to let things dry out while in storage. I am not sure there is any remedy for this besides installing a better skylight, but if anyone has thoughts on fixing this problem it would be greatly appreciated.
tgorney is offline   Reply With Quote
Old 01-08-2015, 08:12 AM   #2
Mddle of the Rd Extremist
MeepMeep's Avatar
Had this problem in my last 5th wheel. Found that it was NOT condensation but a had bad seal around the skylight up on the roof. Applied some sealant and removed the interior portion of the skylight, wiped it all out and reinstalled. Had no further problems with it....hope that helps
Dan, Carolyn & The Bandit (1999-2015 RIP...)
MCPO (Retired)
United States Navy ('65 - '87)
2014 Cedar Creek 38FL
2013 RAM 3500 6.7L diesel DRW Crew Cab
"When you get to the fork in the road, take it....."
MeepMeep is offline   Reply With Quote
Old 01-09-2015, 05:54 AM   #3
Thanks for your input. I'll be resealing it as soon as the weather allows.
Old 01-11-2015, 01:57 PM   #4
B and B's Avatar
I would check the skylight for cracks where the screw holes are. I had 2 replaced under warranty. They overt tightened thy them upon install.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
light
