Old 07-25-2015, 09:23 AM   #1
wuffwuff's Avatar
Connecting Coax Cable
The exterior coax connector (dual tv & satelite) is recessed with a lid to protect it from the weather on my Flagstaff 27rlws. This makes it difficult to screw to coax cable on.
Getting the threads lined up and started is difficult, but it's hard to tighten the connector down as the flip up lid gets in the way.
Do other members have this problem, and how have you remedied the situation.
2018 Cherokee 294rr Toyhauler
2017 Ram 2500 6.4 crew cab, long bed.
It's Easy to take 'Liberty' for granted, When you have never had it taken from You!
wuffwuff is offline   Reply With Quote
Old 07-25-2015, 09:58 AM   #2
Ford Idaho's Avatar
You might like a Paladin.
Paladin Tools 1928 Coax 3-Way Multi-Tool For CATV "F" RG6 - F Connector Tool - Amazon.com
Old 07-25-2015, 10:47 AM   #3
Quick connectors may solve your problem. Available
on line or at the Source. They attach permanently to the screw end
of the coax and simple push on to the exterior connecter when required.
see attached images
mbtelguy is offline   Reply With Quote
Old 07-25-2015, 09:51 PM   #4
mutt's Avatar
Never knew there was such a tool!
mutt is offline   Reply With Quote
Old 07-26-2015, 07:52 AM   #5
wuffwuff's Avatar
Coax Tool
Thanks Ford, Wasn't aware of the tool either. When checking it out, I found some other tools to do the job also.
Old 07-26-2015, 08:44 AM   #6
Ford Idaho's Avatar
Saw this in a store a couple years ago, they sell lots of specialized tools for pro installers.
Like security Torx bits
Old 07-26-2015, 12:38 PM   #7
Adony's Avatar
Almost same problem...resolved
Having fat fingers and a recessed exterior coax cable / sat tv connector on my TT..I experienced the same thing.. At first I used the tool described in previos posts and it worked OK but I was always misplacing it... I came across a Comcast Cable installer who was throwing away a short 3 ft RG6 jumpert cable that had ends on it that were exactly what I needed.. I cut the cable in 1/2, attached a normal compression RG6 connector on one end, connected it to the sat antenna cable with a barrel connector and the other end of the jumper had a connector that was easy to the sat in on the trailer...Pictures are better than words....
Ted
2010 T25KS Wildwood
2006 F-250 SD
STGCM(SW) USN Ret 30 yrs.
Adony is offline   Reply With Quote
Old 07-30-2015, 10:33 PM   #8
paulmac's Avatar
Try something like this. Easy grips come pre-installed. Works great. http://www.amazon.com/gp/product/B00...rch_detailpage
paulmac is offline   Reply With Quote
Old 12-13-2015, 10:47 AM   #9
I finally found the problem with no TV reception. The antenna coax jumper from the batwing antenna that leads into the roof has a little rubber boot that allows rain water to leak into the cable connection at the roof entry. Within one year of purchase the cable connection failed. Its hard to believe that forest river and probably numerous other manufacturers would not see this as a potential problem.
If anyone else has this little boot I would recommend examining the connection and add more flexible sealant to completely cover the boot. After the fact I wish I had taken some photos.
Rockwood 2703ws
Rockwoodjoe is offline   Reply With Quote
Old 12-13-2015, 10:59 AM   #10
see attached images
These make Life so much Easier! Youroo!!
Old 04-09-2016, 10:21 AM   #11
[QUOTE=wuffwuff;934376]The exterior coax connector (dual tv & satelite) is recessed with a lid to protect it from the weather on my Flagstaff 27rlws. This makes it difficult to screw to coax cable on.
Do other members have this problem, and how have you remedied the situation. [/QUOTE
I was just browsing through postings and saw your question. My husband has a solution for this issue. Check out this: www.rvcablegrip.com
Jim & Jacqui
and Jazmin the cat who loves going camping
2007 Coachmen Cross Country
2008 Ford Escape Hybrid
jnjwright82 is offline   Reply With Quote
Old 04-09-2016, 10:31 AM   #12
nomad297's Avatar
Buy Mediabridge coax cable at Amazon. It comes with sleeves for the ends that will work exactly as you want them to.
Bruce
Old 04-09-2016, 11:17 AM   #13
Left Coast
The non screw on ones will you give you a pia moment after a few uses.....they lose their grip...also, the coax connectors in the wall plate might be installed backward....longer end inside
Old 04-09-2016, 11:23 AM   #14
Make sure you get the ones with a split ring on the end of the connector.
They retain their grip even with excessive use.
Days Camped: '16=46 '17=30 '18=51 '19=50
Old 04-09-2016, 11:56 AM   #15
Left Coast
Those haven't found there way out here yet!....Most buyers for HD and Lowes doen't have a clue! lol....And Radio Shack is just about as bad.....have found that the repair packs of ends have a lot better swivels and have a sort of line up action to 'em
