Old 05-15-2019, 05:50 PM   #1
pontiacdan45's Avatar
Send a message via Skype™ to pontiacdan45
Connecting drain pipes
Hello,
Nothing sexy about this. I'm getting older and my hands don't have the strength to overcome the resistance when fitting two sewer pipes together or sometimes fitting the pipe to the outlet. They don't go far enough to be secure and so I wear myself out trying to get then snug.
I would value any suggestions.
Thank you
Pontiac Dan
2015 Rockwood Signature Ultra-Lite 8289 ws
2015 GMC Crew Cab 2500HD Gas:
pontiacdan45 is offline   Reply With Quote
Old 05-15-2019, 06:01 PM   #2
Maybe these would work? Camco Rhinoflex RV Sewer Fitting Wrench Set- Helps You Grip and Loosen or Tighten Swivel Fittings with Ease!| Lightweight and Durable Design |Includes Two Wrenches - (39758) https://www.amazon.com/dp/B00OJHPQSQ..._9Nj3CbRDBYZ33
Skip12 is offline   Reply With Quote
Old 05-15-2019, 06:07 PM   #3
Sewer Pipe
I bought two sets, but they don't overcome the resistance. Should I use WD 40 or petroleum jelly first?
Pontiac Dan
Old 05-15-2019, 06:24 PM   #4
I use 2 oil filter pliers. Those camco things did not work for me. Blaster garage door lubricant would probably help. I would just keep it off the O-ring. I also filled the stubs a couple of times and that helped and still sealed.
Rockwood 2604WS
Ford F250 Diesel
Blue Ox Sway Pro
allenb12 is offline   Reply With Quote
drain
