03-16-2018, 06:26 AM
#41
Originally Posted by Kimber45
They told you to do it at midnight because most places would kick you out for dumping grey water on the ground.
I'm curious how long of a time frame the original poster is camping? If taking showers at the shower house how fast could one fill their tank? I could probably make it a month or more if not showering in my unit.
the COE host just said run the
grey on the ground, I added the midnite option myself. I have run it at all hours of the day if needed.
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
03-16-2018, 06:47 AM
#42
The "MIDNIGHT" part should have been a real Good Indicator that it is "Improper or Illegal"! Youroo!! Kind of brings back Chidlhood memories , "Hey Jimmy TOLD me to Do It"! Youroo!!
03-16-2018, 06:53 AM
#43
Originally Posted by W5CI
Get a long water hose and run grey water out on the ground at midnite if necessary. I had one COE camp host to tell me to do that.
I was just using your Post #17 words! Youroo!!
03-16-2018, 07:50 AM
#44
I've only ever been to one campground that allowed grew water dumping, and that one wasn't 'dump on the ground'. They had plastic 50 gallon drums buried in the ground filled with gravel and pea stone you were supposed to dump into that acted kind of like a septic weeper.
It was not what I was expecting when the Sister in Law who booked the joint sites for all of us said "Sure, there's dump stations at the site" when we asked if she had booked with sewer hookups. She also booked us a 26' site for our 34' overall length, 29' box TT. It was an interesting weekend.
03-16-2018, 07:59 AM
#45
Bene Gesserit Rule
Originally Posted by Lefty59
Although I've never seen it (and hope I never do), out here they don't want you dumping grey water anywhere near a campsite as it can contain some food particles and odors that may attract nearby bears!
Bears do have a very keen sense of smell as I've seen the damage one did to a car parked at a trail head with just an open pack of life savers inside.
I suppose that is one thing we can be grateful for here down under. Our 'bears' are a lot smaller and more cuddly. They eat nothing but a particular type of eucalypt leaf and the worst they do is pee/poop on your roof .
03-16-2018, 08:27 AM
#46
Originally Posted by Larry-NC
Why wouldn't they just put a Valterra cap on the valve assembly and open both of the existing gates? Woouldn't that do the same thing?
Larry
Putting a cap on and opening the valves would accomplish the same thing... as far as equalizing the tanks.
The problem with the cap-vs-the twist on gate valve is with the cap method, when you go to take the cap off to put the sewer hose on, you'll have a mess with what is in the piping between the cap and the existing valves. And before you ask... yes... if you installed the sewer hose at the start before you equalized the tanks, then it's not much of an issue but remember, the OP is at a site with no hook-ups and the dump station is a mile away so the sewer hose won't be connected. The twist on gate valve will allow you to install the sewer hose anytime with no mess and once you do connect it, you'll simply pull the handle to open the twist on valve.
03-16-2018, 10:48 AM
#47
Originally Posted by HikerBob
Open the garden hose connection after you leave the campground and are on the highway. It will drain your grey water onto the pavement or dirt road where it won't be a problem to anything or anyone. Once drained stop and close it. Oh yeah, you may get a few honks from people passing you, but don't let that stop you. However, DO NOT do this with your black water tank.
This has to be a joke.
03-16-2018, 11:49 AM
#48
HikerBob
Originally Posted by Scrapper
Some states will not allow this. In Wisconsin you may get away with it until LEO see the leaking fluid. He will stop you so you can fix the leak. If he notices the leak is intentional, you will get a ticket. Unless he is feeling generous.
We're a little more "fluid" out west.
03-16-2018, 12:29 PM
#49
If you do this.... do not use this hose to fill up your fresh water tank. We have several water hoses for different 'purposes'.... One is only used to bring fresh water into the unit and nothing else.
Brother Les
03-16-2018, 12:56 PM
#50
World Wide Wanderer
Originally Posted by GreenZR
Is it possible to disconnect the toilet supply line from the fresh water supply line completely. Then add a second on demand 12 volt pump fed from the shower grey tank for the toilet? That way you are flushing your business with water from the grey. That seems like that would be a great way to both empty or utilize the grey, and not fill the black tank with fresh good water.
Gary.
Someone makes a system that does just this. I have considered building my own, but it is a ways down the priority list. Things like camping come first!
Aaron
Aaron & Rhonda
wahoonc & Airangel60
2016 Coachmen Concord 300DS
2015 Fusion Hybrid following along
03-16-2018, 01:00 PM
#51
Most RVers will have food particles in their gray water.
So dumping it on the ground will at minimum, attract insects if not animals too.
03-16-2018, 02:03 PM
#52
Larry
same except for the mess when you remove the cap to attache your sewer hose as a mix of grey and black water will be between the cap and the valves.
with the extra screw on gate valve in place of the cap you attach you sewer hose to it when you are ready to dump so no extra mess.
2024 Artic Fox 3018 5th Wheel
Grand Design 2800BH TT 2021 - for sale
Prior TT 2017 Flagstaff 831CLBSS Classic Ultra lite - SOLD 5/21
TV 2024 F350 DRW - on order
Prior TV 2017 F150 6.5' bed 3.5 Eco-boost Max tow 1800lbs payload
03-16-2018, 06:45 PM
#53
Bene Gesserit Rule
Most of use the white/blue 'certified for drinking' type for fresh water.
03-16-2018, 07:04 PM
#54
Being a first time trailer owner (picked it up Feb 18th), I’m learning so much cool stuff.
Awesome thread.
03-18-2018, 11:52 PM
#55
03-19-2018, 01:34 AM
#56
Bene Gesserit Rule
Originally Posted by Mslaman
I/we would presume that everybody else had left by this point. Or do you dig a hole first?
03-19-2018, 08:07 AM
#57
Awesome thread.
Welcome to the Forum.
There are many awesome threads on this forum that you may learn some 'tricks' from. If you do not see a questions answered, please start a thread and you will get a few different suggestions.
Brother Les
03-19-2018, 12:06 PM
#58
Canadian Member
Where are you boondocking?
03-20-2018, 03:29 PM
#59
Chief tinkerer
dish water into black tank
Originally Posted by dahagen
We wash dishes in a plastic tub that fits inside the kitchen sink, then dump the dirty dish water into the toilet.
this Great idea
Gary
2017 SunSeeker 3010DS
03-20-2018, 05:10 PM
#60
Always Learning
Originally Posted by Gidyupgo
this Great idea
Just be absolutely sure you get all of the utensils! Over the years, I’ve read of a couple of “I dropped a spoon down the toilet, how do I retrieve it?!” posts.
