Old 02-21-2017, 08:47 PM   #1
Cordless Drill for leveling jacks
I am looking for tips on how to use a normal 18 volt cordless trip to raise and lower the leveling jacks? What do you connect the socket to the drill chuck? Or do you have to use an in pack gun and not a normal cordless drill? Are most the bolts the same size?
Tom and Kathy
N Ga
Slow but Steady is offline   Reply With Quote
Old 02-21-2017, 08:52 PM   #2
lugoismad's Avatar
I use this
Hex Drill Socket Driver Set 3 Pc
And a deep well 6 point spark plug socket that fits my jacks.
Works great to run them up and down. Make sure to spray your jack screw down with some grease every year to keep them rust free and moving smooth.
I use a Black and Decker Matrix drill
https://www.amazon.com/Decker-BDCDMT...dp/B009VK6G8U/
With the Impact Driver Attachment
https://www.amazon.com/BLACK-DECKER-.../dp/B009V5C58U
lugoismad is offline   Reply With Quote
Old 02-21-2017, 09:05 PM   #3
Walmart sells a Camco unit just for this. Under $14.
Years ago, before I found the actual tool, I: went to Lowe's and bought a socket (19mm?) for a 1/2" drive. I then bought a 1/2" to 3/8" adapter. My drill was 3/8" so the 3/8" end goes in the drill and the 1/2" end goes in the socket.
2015 Shamrock 23IKSS, Oyster shell
2019 Chev Silverado LT Z71 Ext. Cab, 4x4, 5.3L V/8
Reese Straight Line WDH, 2000W Honda Gen.
2 Old Town kayaks & 2 Boston Terriers - Zoey/Gonzo
Lar & Ruth
CNYCamper is offline   Reply With Quote
Old 02-21-2017, 09:19 PM   #4
https://www.walmart.com/ip/Camco-Lev...ocket/29764655
https://www.amazon.com/Camco-57363-L...+drill+adapter
fella10 is offline   Reply With Quote
Old 02-21-2017, 09:20 PM   #5
Flybob's Avatar
If your drill has a torque clutch set it to just firm up the jack . This will prevent accidentally raising a jack too high.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 02-21-2017, 09:23 PM   #6
Ford Idaho's Avatar
Leveling jacks?
What unit do you have FW, TT?
Old 02-21-2017, 09:26 PM   #7
W5CI's Avatar
I burned up my cordless drill first time I tried that, took my 1/2 inch elect drill from then on. Just be careful that will hurt you when it hits the stop
2005 Cedar Creek 30RLBS/TrailAir Hitch/ MORryde 7K IS/Disc Brakes/ PI PT-50 EMS/ RV Flex Armor Roof
2015 RAM 3500 DRW 6.7 Cummins 3.42/ Garmin 760RV
40 Gal TransferFlow fuel tank/ TST 507
Amateur Radio W5CI 2019 Days Camping 25
2020 Days Camping 7
W5CI is offline   Reply With Quote
Old 02-21-2017, 09:31 PM   #8
Mr. Dan's Avatar
One thing Bob is saying ====> your jacks are not leveling jacks; they're stabilizing jacks. Use blocks under tires on one side and your tongue jack for leveling.
Old 02-21-2017, 09:42 PM   #9
dannyabear's Avatar
And please don't get an impact driver; use a plain screwgun
Danny & Darlene
2002 Silverado 1500HD
2014 Rockwood 2703WS 'Emerald Pkg'
Days camped 2015=42 2014=48 2013=41 2012=47 2011=18
dannyabear is offline   Reply With Quote
Old 02-21-2017, 09:47 PM   #10
DW's 401(k) Plan
DaGrinch's Avatar
DITTO!
I had a 1/2" drill dedicated to my pop-up and then carried it on over to my Roo. Left it with the rigs all year. I still have the socket around somewhere.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 02-21-2017, 10:15 PM   #11
yetavon's Avatar
X2......level side to side, then front to back. Then the jacks to secure and add support. I have used a B&D 20 volt drill, set on 10 and run up till it gives....2 years issue free....
Retired Paramedic
2020 FSX 280RT
2005 Silverado 1500 Ext cab 5.3 H.O.
2011 HD Road King
Nights camped since 2019.....all of Em...Homes a 2001 Sea Breeze 36' 5 ER
yetavon is offline   Reply With Quote
Old 02-21-2017, 10:20 PM   #12
SailorSam20500's Avatar
Dewalt 20 volt. Works like a champ.
Al
I am starting to think, that I will never be old enough--------to know better.
Tolerance will reach such a level that intelligent people will be banned from thinking so as not to offend the imbeciles. Fyodor Mikhailovich Dostoevsky, Russian Novelist
S.E. Mich. Flagstaff 26FKWS / 2022 F-150 3.5 EcoBoost SCrew Propride
SailorSam20500 is offline   Reply With Quote
Old 02-21-2017, 10:23 PM   #13
Always Learning
Agreed. Level side to side using blocks under the tires. Then front to back using landing gear/tongue jacks.
More info here:
http://learntorv.com/rv-leveling-is-...uick-and-easy/
I use a simple 14.4v DeWalt drill/screwgun for my scissor jacks.
Old 02-21-2017, 11:13 PM   #14
I use a Makita cordless that has 8 torque settings. With the torque release set to the next to maximum setting I run each stab down until the torque release activates. That way I know there is equal pressure on each one.
After doing that I follow up with 1.5 turns with the hand crank on each one. Unless I'm parked on concrete I check each day and usually add another turn to all six stabs. Even with the 12x12 pads permanently bolted to each stab they still loosen up a little bit every day.
BIRDS AREN’T REAL
Old 02-22-2017, 03:24 PM   #15
Those are not levelling jacks! They are for stabilization. Do not try to level the trailer with them
Magdeep is offline   Reply With Quote
Old 02-22-2017, 03:49 PM   #16
don't need a drill, that's my 12 year old daughter's job... we'll see how long I can get away with having her do it before I need to get myself an extra drill for the camper...!!
Shawn
Chief, U.S. Coast Guard Reserve
2019 Sport Trek ST270VBH
2018 Chevy Silverado Z71
Shawn.O is offline   Reply With Quote
Old 02-22-2017, 05:07 PM   #17
Depends on the size of the trailer frame.
BIRDS AREN’T REAL
Old 02-22-2017, 07:13 PM   #18
I use an 18v 1\4" impact with socket adapter and 3\4" ( I think) socket, didn't want to waste money on a campco adapter, when I have the tools.
2015 Tracer ultra light executive edition 3200bht
2007 Dodge Ram 3500 Cummins 6.7, Dually, crew cab, long bed
SilverArrowPro is offline   Reply With Quote
Old 02-22-2017, 07:56 PM   #19
djemgoss's Avatar
cordless drill for stablizing jacks
I use the same attachment as "fella10" uses! I use my Milwaukee M12 3/8 cordless drill and it works great!!!
Dave & Elaine
Brookfield, WI
2021 Rockwood, 2509s, pulled by a 2020 Ford F150 XLT, Super Cab, 3.5L Eco Boost, with 3.55 axle. Electric 10-speed auto trans w/tow mod. Heavy Duty Tow package & integrated trailer brake, 11,700 lb. tow capacity, payload is 1916 lbs. and 145” wheel base. Equalizer 4 point W/D hitch.
djemgoss is offline   Reply With Quote
Old 02-22-2017, 08:12 PM   #20
satdog01's Avatar
Picked up adapter off Amazon. Leave it with cordless 18v drill. That way keep all my sockets together in tv.
2020 Georgetown 31L, Safe T steering, Sumo springs, Onan Geny
2015 GMC Canyon 4X4 TOAD w/Blue Ox tow plates, InvisiBrake
Pepper 🌶 PomChi rescue 545 nights as our camping buddy
Days camped in FR 2011-12 = 77, 13-14 = 98, 15-16 = 129
17 = 81, 18 = 44, 19 = 83, 20= 45, 21 = 76, 22 = 57, 23 = 42
Retired :
satdog01 is offline   Reply With Quote
jacks, leveling
