Old 01-20-2013, 08:43 AM   #1
Corrosion blocking spray
This week we will be taking delivery on our new trailer and would like suggestions on preventing corrosion. The trailer will spend most of of the time near the ocean so rusting landing gear etc. is a real concern.
Are there suggestions on a product that might be helpful?
Patrick45 is offline   Reply With Quote
Old 01-20-2013, 08:46 AM   #2
rattleNsmoke's Avatar
Don't know if it's still in use, but Cosmoline is a gease-like product applied to slow corrosion. Maybe someone more knowledgable will chime in.
rattleNsmoke is offline   Reply With Quote
Old 01-20-2013, 09:20 AM   #3
Oklahoma Proud
MillerTime's Avatar
I work in the collision industry, so we are always concerned about corrosion. Unfortunately the best thing to prevent it is to have a galvinized coat and then an acid based primer and then a quiality top coat of paint. But since we can't get that on our trailers here's a couple of tips I can give.
#1- keep the frame clean- sounds simple but mud or dirt will hold moisture against the metal.
#2- you can get a ruberized undercoat from 3M, SEM, and other brands, kind of pricey, I think about $8-10 a big can. It is like a spray on bedliner but it doesn't dry hard like bedliner. And you can spray your frame with it. ( I've used about 3-4 cans on crew cab truck frames)
#3- if you notice any chips or rust spots near corners or bends, scuff the spot with a scotch brite or sandpaper (like 150-220 grit) and apply some etch primer and then some paint over the spots.
Possibly mud flaps on the tow vehicle or even behind the wheels on the trailer can help with the dirt and rock chips.
We don't have the perfect solution to prevent rust, but this should be better than factory!
Old 01-20-2013, 09:45 AM   #4
I have used the under coating you speak of and would like to know if it is flexible enough to use on landing gear that is extended and retracted.
Old 01-20-2013, 09:53 AM   #5
Oklahoma Proud
MillerTime's Avatar
If it is like a scisor jack, I think it would work. If drop legs, like the front of a 5er, I think it would rub off.
Old 01-20-2013, 10:02 AM   #6
jevanb's Avatar
LPS 3 is what we use in the acft industry and other stuff but you can't get ahold of the other stuff
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
jevanb is offline   Reply With Quote
Old 01-20-2013, 10:31 AM   #7
I am reading about Corrosion Block by Lear Chemical. I have seen it around boats here on the coast.
Old 01-20-2013, 04:29 PM   #8
mduff's Avatar
We coated the underside of our TT with a product called Rust Check, recommended by a number of fellow campers here in Canada. Site indicates available in eastern states.
Mike and Brenda
TV - 2013 Silverado 1500, 5.3L
TT - 2012 Wildwood 26 TBSS
mduff is offline   Reply With Quote
Old 01-20-2013, 10:04 PM   #9
jevanb's Avatar
corrosion block like ACF 50 removes moisture and leaves the cell dead. but does not protect the metal from future corrosion. perockotone (spelling)
is installed at most factories ( Boeing,Lockheed) and coats the metal so moisture can not attack
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 01-22-2013, 10:38 AM   #10
Someone today told me that they have regularly sprayed their landing gear and undercarriage with automatic transmission fluid. He claimed that his 7 year old fifth wheel had little to no rust after all those years on the beach.
Old 01-22-2013, 01:07 PM   #11
jevanb's Avatar
motor oil works also, anything to coat is better then nothing
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 01-22-2013, 01:21 PM   #12
B47
Agreed - just remember - in simple terms, rust is simply what happens when the metal it is on is trying to return to its natural state.
Anything product that is applied to the metal that "blocks" or "coats" the metal and prevents that decaying process will go a long way in preventing rust and its subsequent effects.
Old 02-01-2013, 03:55 PM   #13
BigTJohn's Avatar
Boeing developed T-9. It is one of the best things out there for corrosion prevention. It is/was used extensively on aircraft carriers to prevent planes from corroding in the harsh salt air. Good stuff, can be a little pricey, from 17.99-24.99 depending on where you get it. I use it on all our stuff open to salt air - I live on a canal and the screen door closer will rust away quickly. I am still on the original on after 12 years. Neighbors have replaced theirs 2 times in 8 years (won't listen to suggestions).
Brenda and John
Master Blaster of the Navy
BigTJohn is offline   Reply With Quote
Old 02-02-2013, 10:53 AM   #14
jevanb's Avatar
15 years for Boeing, 4 at final Assy, 1 at the Northrop factory California, and the rest at NAS Pax VX 23, flight test and never heard of that FA18,T45,X31,AV 8 platforms
2012 Wildcat 344QB
06 LBZ ,CC 4x
lots of mods
Superglide
Old 02-02-2013, 11:39 AM   #15
Salt X
Salt X or Salt Eliminator..........T-9 is also great stuff. Used the first 2 on my sailboat. Still use it now when we get home from the beach..........anything and everything metal gets hosed down with it....including bikes.
Trevor43 is offline   Reply With Quote
Old 02-02-2013, 01:46 PM   #16
cstover's Avatar
I am in the Coast Guard and use it quite a bit. I use it on 50 cal weapons mounted where they are exposed (and repeatedly doused with) to salt water.
cstover is offline   Reply With Quote
