Old 06-19-2017, 10:04 AM   #1
Covering RV for several months
I am getting ready to cover my Trailer for the summer. We travel from NJ to Florida after Jan 1st to get away from the winter weather. My question is do I leave the windows open or close them before I place the cover on my trailer?
padave2 is offline   Reply With Quote
Old 06-20-2017, 07:56 AM   #2
I would close the windows but vent the trailer. To bad you can't use it during the summer to RV in the Adirondack's!
whj77372 is offline   Reply With Quote
Old 06-20-2017, 08:06 AM   #3
Flybob's Avatar
Close the windows. If you have access to power, I would add a small dehumidifier that has the drain option so you do not have to continually have to empty the container. You can run the drain hose to the shower drain and leave the grey water drain valve slightly open. It should not drain enough water to cause a problem. I ran my drain directly out the bottom covering under the shower. There was easy access to the coroplast belly cover from under the shower.
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
cover
