Old 09-21-2015, 11:28 AM   #1
NCBBA11043's Avatar
Cribbing - 6x6 or concrete blocks
Well, there's a chill in the air, and there's only 6 weeks or so of camping season left. So I'm thinking - we have a new 5er with the 6 point leveling system. Directions say to clean/lube frequently. Gonna be difficult to do while in winter storage (several miles from home). So I thought I would use enough cribbing to keep the front hydraulic cylinders retracted as much as possible. What would you all recommend: 8x8x16 concrete blocks stacked (changing direction with each course as required) with a 2x piece of wood on top, or a bunch of 6x6 pressure treated lumber in a traditional cribbing formation?
NCBBA11043 is offline   Reply With Quote
Old 09-21-2015, 11:36 AM   #2
Sc00ter's Avatar
Flipped our axles a couple of years ago and used all the above. Had leftover high density concrete blocks on the bottom, the softer wood on that (actually had some rot on top) conformed beautifully to the shape of the frame and shored up the rest with Jack stands. Whatever method used, I would suggest some wood (2x4s or the like) as a go between the frame and the hard stuff.
2015 puma 295bhss
2009 ram 3500 6.7l ctd
Sc00ter is offline   Reply With Quote
Old 09-21-2015, 11:40 AM   #3
Blackrock's Avatar
Cinder blocks are, well, made out of cinders. Myself I wouldn't use more than one of them on each stack. If you could get a RR tie to reach all the way across then crib up from there with wood should work better.
Illegitimum non carborundum
Blackrock is offline   Reply With Quote
lock
