Old 05-04-2016, 06:36 PM   #1
Cricket SX3
For those who have heard about the elusive Cricket mini golf cart but haven't seen one. Here's mine beside of our regular sized cart. It's sort of hard to see but I have the back of the Carts excluding their back steps lined up so the difference in length shows in front.
It fits in my shorter than normal F150 5.5' bed if the back step is off. Easy off with a few twists of the knobs that hold it on. No tools required. If you need it shorter than that take the floor plate out and shove and it's a full foot shorter.
Perfect solution to my parents' mobility problems without resorting to a toyhauler. I had first looked at toyhaulers, but I felt like I was buying the Trailer for the golf cart instead of me. Would also be a problem in campgrounds where they don't allow carts, where with this I can just leave it in the truck at those places.
Loving it so far. The charger is on board so you can plug it in anywhere. Its a little hard to get used to accelerator/brake wise since it doesn't have a brake pedal and relies on engine braking. Pro tip...if you are going fast on gravel don't lift your foot suddenly!
ID:	106909   Click image for larger version
ID:	106910   Click image for larger version
RackOnInNC is offline   Reply With Quote
