Old 08-16-2016, 08:21 PM   #21
Left Coast
After much trying to do an internal lighting of deflapper poles, decided to do an external mod......work'n on it today and tomorrow, but need to order a few items..probably a week away from gett'n any pics.......
Old 06-07-2017, 10:35 AM   #22
DW's 401(k) Plan
DaGrinch's Avatar
Originally Posted by OldCoot View Post
Designed by Bob Caldwell, here are pictures of how mine are installed. I have now purchased another pair of the Camco Deflappers so I can put 2 on each end of the awning.
BTW, I think Bob did a great job. Thanks OCW!
Hey Bob or Old Coot..,
What do the last two pictures depict? Is that Velcro on the end of the outside of the last picture and Velcro in the inside of the next to last? Is that to take up the slack of the inner pole? And what material did you use.... Metallic EMT?
Thanks.... Larry
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 06-07-2017, 02:18 PM   #23
Thanks.... Larry
The material is the fuzzy side of Velcro to take up slack and prevent scuffing the powder coating. I now have a set of alum tubing de-flappers and use two Camco deflappers on each end of the awning. Yes, they were metal EMT that Turbs made for me.
Old 06-07-2017, 02:47 PM   #24
DW's 401(k) Plan
DaGrinch's Avatar
Thanks, OC, I appreciate the info![emoji106]
Old 06-25-2017, 02:19 PM   #25
DW's 401(k) Plan
DaGrinch's Avatar
Okay, OC, hopefully just one last question..... I was getting ready to drill my hole for the fixed pivot point at the top (picture #2 in the initial post) and I figured I'd better look one more time at where Bob's was drilled. Was a pop rivet drilled out and the bolt run through there? Kind of looks that way.
Thanks.
Old 06-25-2017, 05:12 PM   #26
Thanks.
Yes, it is a rivet you drill out. I used a ss 1/4" eye bolt that I straightened out because I also hook a sun screen over the same bolt.
Old 06-26-2017, 07:00 AM   #27
DW's 401(k) Plan
DaGrinch's Avatar
Thanks, OC, I appreciate the help.[emoji106] [emoji106] [emoji106] [emoji106] [emoji106] [emoji106]
Old 06-30-2017, 05:49 PM   #28
Not for everyone I guess. Even at lowest position, my trailer sits so high, the base of awning tube is still 7' above ground. In sudden storm I wouldn't be able to undo it without ladder. Seen enough awnings lost to sudden gust fronts. It is a nice design.
TheWolfPaq82 is offline   Reply With Quote
Old 07-08-2017, 08:24 PM   #29
DW's 401(k) Plan
DaGrinch's Avatar
TaDa! MANY THANKS to Bob for the design and Old Coot for giving the details. Now, to get a set of the wide deflappers.
Old 07-18-2017, 06:51 AM   #30
Georgia Rally Coordinator
aceinspp's Avatar
Thanks DaGrinch for posting that pic. Just got my poles few weeks ago and needed some good pics of install. Do you remove the deflappers when retracting the awning? Later RJD
Traded 2015 30WRLIKS V-Lite
Days camped 2019 62
dometic, awning, electric
