Old 08-12-2016, 09:00 AM   #1
Deflapper poles for Dometic/A&E Electric awnings
Designed by Bob Caldwell, here are pictures of how mine are installed. I have now purchased another pair of the Camco Deflappers so I can put 2 on each end of the awning.
BTW, I think Bob did a great job. Thanks OCW!
Name:	Awning deflapper 1.JPG
ID:	116990   Click image for larger version
Name:	Awning deflapper 2.JPG
ID:	116991   Click image for larger version
Name:	Awning deflapper 3.JPG
ID:	116992   Click image for larger version
Name:	Awning deflapper 4.JPG
ID:	116993   Click image for larger version
Name:	Awning deflapper 5.JPG
Name:	Awning deflapper 6.JPG
ID:	116995   Click image for larger version
Name:	Awning deflapper 7.JPG
ID:	116996   Click image for larger version
Name:	Awning deflapper 8.JPG
ID:	116997   Click image for larger version
ID:	116999   Click image for larger version
Old 08-12-2016, 11:37 AM   #2
B and B's Avatar
Are you manufacturing/shipping these?
Old 08-12-2016, 11:46 AM   #3
Georgia Frog Rally 2017
aceinspp's Avatar
Great job Bob, looking good. Later RJD
2015 Chevy 2500 6.0 4:10 gearing.
Days booked for 2016--60 missed by 2
Days camped in 2016 58
Days booked so far in 2017 37
aceinspp is online now   Reply With Quote
Old 08-12-2016, 02:43 PM   #4
No, I'll leave that to Bob or Turbs.
Old 08-13-2016, 12:58 PM   #5
Carknocker Family
Ida Ratherbe Camping's Avatar
How do you deploy/retract awning. You have to use a ladder to install each time? What does it look like when awning stored. Pics please. The geometry that I see, won't let me stow awning without removing pole with a ladder.
Maybe I just can't see it.
Nights camped 2014...26
Nights camped 2015...20
Nights camped 2016...20
2005 Dodge 2500 5.9 Cummins 6 speed manual
2014 Salem 32BHDS
Ida Ratherbe Camping is offline   Reply With Quote
Old 08-14-2016, 06:16 AM   #6
Left Coast
The de-flapper pole stores just like the awning pole....just off to the side ..,I deploy awning, pull the roller down and tighten tilt adjustable knob, swing de-flapper pole up to roller, slide de-flapper on, slide pole onto outer stud, install de-flapper onto material, release tilt adjuster, and then lower awning pole.....very easy job
Sent from my XT1585 using Tapatalk
Retired....but work part time as a pain in the north end of a south bound donkey.......2010 Rockwood 8280 5er....99 Dodge 2500 turbo Cummins
bob caldwell is online now   Reply With Quote
Old 08-14-2016, 06:22 AM   #7
Left Coast
Ladder not needed....pole stays attached at top, and just slips onto stud at roller end.....deflapper hold the pole in place. Then after removing deflapper, pole swings down next to arm on trailer and stores there....no need to remove to store as they telescope together for length...
Old 08-14-2016, 07:55 AM   #8
B and B's Avatar
This could void your awning warranty. Much like adding a bike rack.
Old 08-14-2016, 08:00 AM   #9
Left Coast
Weigh less then a 6 pac....lol
Old 08-14-2016, 08:07 AM   #10
Same pole setup supplies a mounting point for end Sunshade! I only drilled 1 hole in vertical awning mount and used a longer bolt through the outer vertical pole mount,very quick and easy install! Youroo!!
dometic, awning, electric
