Old 11-01-2015, 07:56 AM   #1
Loneeagle's Avatar
Dehumidifiers
What is a good humidifier for a 22' Flagstaff Microlite that's been winterized...May use it some this winter but want to keep the humidity under control. I've seen some that look like they are just chemical bases so the don't have to be plugged in. Words of Wisdom? Thanks.
Ford F-150 4X4
2015 Flagstaff Micro Lite FRBS
2013 Flagstaff "A" Frame - Traded Up.
Camping Days 2013 - 24
Camping Days 2014 - 21
Projected Camping Days 2015 - 30
Loneeagle is offline   Reply With Quote
Old 11-01-2015, 08:08 AM   #2
Witch Doctor's Avatar
I used to use I think it called Rid Damp, comes in a container. The bigger the better, also keep it in your sink, you will be surprised at the amount of water they collect, works great and NO ELECTRICAL needed. You will still need to dump the water out from time to time.... I used two on a 40' sail boat. Never had mildew.
Coachmen M/H
Concord
2018 / 300 DSC
Old 11-01-2015, 08:41 AM   #3
Loneeagle's Avatar
Thanks for your reply. I'll check that out. My TT will be stored in Myrtle Beach probably January - March/April so won't be able to get to it during that time. I'll be using it through the end of the year.
Ford F-150 4X4
Old 11-01-2015, 08:50 AM   #4
VinceU's Avatar
Damp Rid, laundry section of Walmart.
Old 11-01-2015, 09:27 AM   #5
Night Stone's Avatar
I found it in the RV section in Walmart
98 Chevy Silverado C3500 crewcab, 454 cu in & 2013 Salem Cruise-Lite 181BHXL
FRF and FROG member
Days camped in 2012 (3), 2013 (3), 2014 (6)
Days camped in 2015, 0 Days so far (0)
This Space for Rent
Night Stone is offline   Reply With Quote
Old 11-01-2015, 10:48 AM   #6
Loneeagle's Avatar
Sounds like a plan. Thanks everyone for your help.
Ford F-150 4X4
